Question about InFocus LP70+ Multimedia Projector
Infocus LP70 - It's all Green
Hi:
The projector intermittently projects an "all green image". No other colors. Not every time, and sometimes a reboot fixes it - Should I do a factory reset on the service menu - or is this a lamp at the end of it's life.
Any help would be appreciated
  • Anonymous Feb 12, 2008
    Very yellow/green image when I display Powerpoint Presentation or any laptop image - images from the projector alone are bright w/vivid colors.
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Posted on Nov 21, 2007
How to set my LP70 into Flash mode?
Posted on Dec 21, 2007
This projector is projecting a red color throughout. What should I do to correct the color? It has been turned off for about an hour. Please advise. Thank you.
The EX240U uses a DLP imaging chip and a rapidly spinning six-segment color wheel (red, blue, green, white, yellow and cyan) to form the image. It is likely that the spinning color wheel has stopped with the red filter in front of the chip. I recommend opening the projector and see if you can coax the wheel to move and maybe it will spin once again. if not, it may be the wheel motor or the circuitry that affects the timing of the spin - either way, it will take a trip to the repair shop to fix.
Hope that helps.
Mar 05, 2015 | Mitsubishi EX240U Projector
The image color on projection is not the same as shown in laptop. There's is no red color.
It could be a broken connection in the computer lead for the red signal, or a fault on the projector that the red panel doesn't work any more.
To diagnose, bring up the projector's on screen display. If there's white in the menus then the problem is the cable. Replace it with a new one. If the menus are affected too then it's a projector problem. This requires the attention of a service engionner.
Aug 20, 2014 | Toshiba Tdp-s25 1080i 720p Hd Dlp...
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
Mar 02, 2011 | InFocus LP 250 Multimedia Projector
IXD 420U projector takes a long time to project and has pink ima
If possible, try to replace the VGA cable between the projector and the computer. A bent or broken pin, or a damaged wire, can prevent the blue or green (or both) portions of the picture from being displayed. The result is a reddish/pinkish picture.
As for the long time to project an image, this could be an extended warm-up time. How old is the bulb in the projector? Does the projector have an option to display the hours used and/or remaining on the bulb? Bulbs do have a finite life, and when they near the end of their service life, they can become more difficult to start.
Hope this helps!
Feb 22, 2010 | Office Equipment & Supplies
Light does not come on, fan is working and green light at top keeps blinking off and on on a LP70 infocus projector
if you hear a high-pitched whir, the problem is either the ballast or the lamp. if you don't, it's the colorwheel. you could try to get the parts from an infocus service center or send it in to them for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 22, 2009 | InFocus LP70+ Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
I have infocus lp70 model projector. i replaced the bulb and now it won't light. i put back in the old bulb and the light still wont come on...any ideas? You can tell that the projector wants to run and is...
if you don't hear a high-pitched whir, your colorwheel needs replacing. you can remove the lamp and see the colorwheel inside (colored glass wheel). if you turn it on without the lamp, the colorwheel should still spin. if it does, you have a ballast problem. if not, the colorwheel. you'd still need to send it in to an infocus authorized service center. try av solutions in ny. they're pretty good.
Oct 22, 2009 | InFocus LP70+ Multimedia Projector
Wont light up
the colorwheel needs replacing. if the colorwheel won't spin, the lamp won't light. if you hear a high-pitched whir, the colorwheel works, which means there is a power supply issue. there is a fix for that, but you have to be good at soldering. if you are give it a try: http://www.infocus.com/service/asc/communications/tech_notes/2006/09/tn495g.pdf
Oct 05, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70
Have you tried another lamp? Sometimes thats your problem, but I've seen a several occasions that the a defective power supply causes this symptom. Do you see an image flicker before the projector shutsdown? I do have some spare parts for this projector.
I'm on Ebay - gtitubro if you want to contact me through there.
Sep 17, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
2,049 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
