Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
Tv turns itself off and then back on with audio only
Samsung hlp 5085w dlp rear projection tv
a brand new bulb and housing were just installed so i don't think
that is the problem this time. after tv is unplugged for a few hours it will begin to work normally again for about 20 minutes and then start turning
itself off and on again. there are no warning lights or symbols that i can see when this happens. i thought it might be an overheating issue, but the fan is working. has anyone seen this problem?
  • 261 Answers
Well it might be an issue with your ballast, since it might not be sending enough voltage to the lamp or it can be sending more than it should. i recommend you pout more attention and notice if there's a clciking sound, discountdashmerchantdotcom
Posted on Jul 22, 2009
We have a samsung DLP tv model number HLP 4663W tv. The picture went so we replaced the bulb. Still no picture and the tv makes a noise that sounds like a fan and the tv cycles on and off by itself. ...
Yes, almost certainly a bad color wheel, see attached photo.
If you remove the lamp and look in the direction it faces you should be able to see the wheel, look for it to be missing pieces or shattered.
You Tube has detailed video instructions for replacement in most of the Samsung sets; I have replaced dozens of the wheels.
Before you rate my solution let me know if you have any questions by commenting here.
SD TECH
Jul 08, 2011 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
DARK PICTURE ON MY SAMSUNG DLP/HD REAR PROJECTION TV
It sounds like you need to buy a new bulb, this is what usually happens when the bulb is burning out this bulbs are made to last 6000-8000 life hours
http://www.discount-merchant.com/
Nov 21, 2008 | Samsung HLP4674W 46" Rear Projection HDTV
Samsung dlp hl-p4663w
you need to find out what mage it blow to get the tv to work again
Oct 23, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
I need to order a replacement DLP lamp for Model#HL P 5085W is online the only place to reorder?
Hi, may I know exact model and brand of your TV to provide you helpful info.
Aug 15, 2008 | Televison & Video
Samsung HLP5063W DLP
no you do not need a bulb you will need to have the color wheel replaced.
Aug 04, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
HLP5085W
If you look in the back of your tv, you should be able to see the light from the bulb, if the bulb isn't working no light.
Oct 12, 2007 | Samsung HLP5085W 50" Rear Projection...
Samsung DLP HL-P5063W
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
350 people viewed this question
Henry  Thomas
Henry Thomas
