Polaroid FLM-2632 Television
Problem for Polaroid FLM-2632 Television
NO Picture or Sound on my FLM 26-32
By bm386251 on Jul 22, 2009
i get no picture or sound on my flm-2632 when i pess the power button the led turns blue but will not turn off unless i unplug tv anyone have a solution
Solution #1
posted on Nov 24, 2009
Not Rated)
Fryertuc
Rank: Master
Rating: 98%, 4 votes
Either one of two problems, the main power supply has an issue or has gone bad. 'Not supplying the correct voltages to your processing/controlling board' or that you are having problems with your processing/controlling board. My guess is the main power supply board.
A Good TV Service Shop would give you an idea of what the cost of repair should be. Call around.
Blessing,
A/V Media Tech Guy
Was this helpful?
Yes
No
Popular Solutions for Polaroid FLM-2632 Television
Questions and Unsolved Problems for Polaroid FLM-2632 Television
Do you recommend Polaroid FLM-2632 Television?
Answer
Answer
I am having problems connecting my DVD recorder to my Polaroid TV via the component connector as... (More)
Answer
polaroid 42" Flat Screen says no signal
Answer
poloroid flm15168 what is the code so my directv remote will operate the TV also?
Answer
i have a coby TF-TV1901 (19"lcd flatscreen).hooked cable up and had picture for 2 seconds then... (More)
Answer
TV is about 18 mos old and during last mos have noted a black line forming from top to bottom and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Polaroid FLM-2632 Television:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
