Question about Sony DDS SDT-S9000 DAT Tape Drive
Tape drive backup errors: write error & sense key medium error
Tape drive backup errors: write error # blockes into volume & sense key Medium Error
Red Hat Enterprise Linux ES release 3 (Taroon Update 3)
* SCRIPT:
#! /bin/sh
/bin/mt -f /dev/st0 stat
/bin/mt -f /dev/st0 rewind
/bin/mt -f /dev/st0 setblk 0
/sbin/dump 0f /dev/st0 /dsp/client
* OUTPUT:
SCSI 2 tape drive:
File number=0, block number=0, partition=0.
Tape block size 0 bytes. Density code 0x42 (no translation).
Soft error count since last status=0
General status bits on (41010000):
BOT ONLINE IM_REP_EN
DUMP: Date of this level 0 dump: Tue Jul 21 18:12:00 2009
DUMP: Dumping /dev/sda3 (/local (dir /clientcode/wcl)) to /dev/st0
DUMP: Added inode 8 to exclude list (journal inode)
DUMP: Added inode 7 to exclude list (resize inode)
DUMP: Label: /local
DUMP: mapping (Pass I) [regular files]
DUMP: mapping (Pass II) [directories]
DUMP: estimated 3450974 tape blocks.
DUMP: Volume 1 started with block 1 at: Tue Jul 21 18:12:01 2009
DUMP: dumping (Pass III) [directories]
DUMP: dumping (Pass IV) [regular files]
DUMP: write error 169120 blocks into volume 1: Input/output error
DUMP: fopen on /dev/tty fails: No such device or address
DUMP: The ENTIRE dump is aborted.
/dev/st0: Device or resource busy
* EXTRACTS FROM 'dmesg':
CI SCSI HBA DRIVER, Rev 6.2.36
aic7899: Ultra160 Wide Channel A, SCSI Id=7, 32/253 SCBs
scsi1 : Adaptec AIC7XXX EISA/VLB/PCI SCSI HBA DRIVER, Rev 6.2.36
aic7899: Ultra160 Wide Channel B, SCSI Id=7, 32/253 SCBs
blk: queue f7fd6014, I/O limit 4095Mb (mask 0xffffffff)
(scsi1:A:6): 160.000MB/s transfers (80.000MHz DT, offset 127, 16bit)
blk: queue f7fda614, I/O limit 4095Mb (mask 0xffffffff)
Vendor: CERTANCE Model: ULTRIUM 2 Rev: 1862
Type: Sequential-Access ANSI SCSI revision: 03
Attached scsi tape st0 at scsi1, channel 0, id 6, lun 0
IA-32 Microcode Update Driver: v1.13 <tigran@veritas.com>
microcode: No suitable data for cpu 0
st0: Block limits 1 - 16777215 bytes.
lp: driver loaded but no devices found
audit subsystem ver 0.1 initialized
Linux agpgart interface v0.99 (c) Jeff Hartmann
agpgart: Maximum main memory to use for agp memory: 1919M
agpgart: no supported devices found.
[drm:drm_init] *ERROR* Cannot initialize the agpgart module.
st0: Error with sense data: Current st09:00: sense key Medium Error
Additional sense indicates Write error
st0: Error on write filemark.
st0: Error with sense data: Current st09:00: sense key Illegal Request
Additional sense indicates Invalid field in cdb
st0: Error with sense data: Current st09:00: sense key Hardware Error
Additional sense indicates Internal target failure
st0: Error with sense data: Info fld=0x7fffff, Current st09:00: sense key Medium Error
Additional sense indicates Unrecovered read error
* Info from client:
- last 3 weeks backup tape failed
- cleaned tape drive on multiple occasions
- tried 3 different tapes
- at no point has the 'error light' come on on the actual tape drive
- will order a new set of tapes
* Any ideas please? eg:
- tapes?
- tape drive?
- cables?
- other hardware?
- needs '-I #errors' in dump command - but wouldn't error show something like 'More than 32 block read errors from' if this was the cause?
Any help would be greatly appreciated thanks :)
Access to backup from another pc
Assuming you have a backup on a transportable medium, install the program with which you made the backup on the 2nd pc and use this program to restore from this medium!
Mar 12, 2014 | SimpleTech Computers & Internet
Library C7145 - Back Magazine is not usually recognized
This could just be muck and dirt in the library. The Mag needs to insert fully and be seen by the library.
Give the Mag itself a good visual inspection to make sure there are no broken pieces of plastic, and also clean out the space it sits in the library with a dry cloth or duster.
New Mags are available from www.tape-drive-repair.com as well as cheap repair options.
If you let me have more details as to exactly when this error occurs, then we can better track down exactly what is the issue. Either way this should be fairly cheap and easy to solve.
Sep 19, 2013 | HP C7145-60006 DLT tape Magazine...
We are having an issue with our backups. The system event log says there is an error 7 and lists the tape drive as having a bad block. However the quantum diagnostic tool shows the drive to be healthy. ...
Event ID-7 is a "Bad Block" on the Tape being using. By design, when a Bad Block is encounter, the Tape Drive "Seizes the Tape" and goes offline. It can sometimes be difficult to get the Tape Drive to release the Tape. Refer to the Users Manual for instrcutions on how to Reset the Tape Drive. Sometimes applying the Firmware Update willl reset the Tape Drive and Eject the Tape.
Do not assume the Tape is Bad, but do not re-use until tested. The Tape may be Bad, the Tape Drive may simply need Cleaning or the Tape Drive may be Worn or Damaged. If you are using 3rd Party Backup Software, such as Backup Exec or Yosemite, you wan want to check the Removable Storage Servcie to see if it is set to Manual or Automatic. Any Tape Devices would need to be first Deleted in the Library Section of Removable Storage, then Sop and Disable Removable Storage. Since Removable Storage is in effect NTBACKUP, this Service can interfere with the Operation of your Backup Software and generate "Bad Block" Errors.
To Test the Tape with your Quantum Tape Drive, use a tool called XTALK ( xTalk-6.4.1.1_Quantum_Setup.exe ) that is found on Quantums Website http://www.quantum.com/ServiceandSupport/Index.aspx
You may run a write_read_full Test on the Tape. Be sure to Clean the Tape Drive first. If it fails the Tape, try it with a 2nd Tape, If it fails again, suspect the Tape Drive.
OldCountry73436
Oct 04, 2010 | Quantum DLT-V4 DLT Tape Drive
I get an error message in Toast. On my MacBook Pro the message reads 'Sense Key = MEDIUM ERROR' and 'Sense code = 0x73, 0x03'. Is this a dirty lens?
It can be dirty lens/ drying laser or glitch in software.. Clean your lens, check for laser adn reinstall drivers for toast. If still does not work then provided me your os version, toaster brand - hardware and software name.
Jul 05, 2010 | Apple MacBook Pro Laptop Computer with...
MATSHITA DVD-R UJ-85J error in burning
cud be poor quality disks you are using, depends
macs are quite reliable so I cant blame the drive itself
toast isnt part of mac and there are reliablity issues from it.
Jun 04, 2010 | Apple 17 MacBook Pro Notebook Computer ...
The drive reported an error: sense key-medium error sense ode= 0x0c write error iomega 48x24x48x cd/rw usb burner
this is almost certainly a dirty lens on the writer. clean it with a lens cleaning disk.
May 07, 2009 | Iomega (32885) CD-RW Burner
New Mac ibook
I would suggest that you take it to the apple store and they should be able to fix it for you.
Jan 10, 2009 | Pacific Digital (U30274) DVD±RW...
Medium changer did not show
Check that the unit is set to random mode instead of sequential mode
(FYI Sequential mode treats the whole machine as a single big tape, while random lets the software say what tape is going to be used.)
Aug 07, 2008 | Quantum ValueLoader SDLT 320 Super DLT...
TDK CD-RW Burner Sense Key Error
You may try this dvd creator for mac, I always use it to burn music and dvd, it works pretty well for me
http://macdvdcreator.mac-dvd.com
Mar 28, 2008 | Computers & Internet
Sony DDS SDT-S9000 DAT Tape Drive Logo
1,542 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
