I'm trying to program my Philips 7 in 1 SRP5107/27 Remote Control to each of the devices that are mentioned and I can't get the proper codes or instructions to do so.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
SOURCE: need the code for my remote
codes for magnavox tvs: 0054, 0030, 0179, 1254, 1454
the programming procedure is as follows:
1) turn on tv
2) on the remote, press "tv"
3) press and hold set until the led blinks twice, release set
4) enter the 4 digit code, light should blink twice
5) aim remote at the tv and press power, the tv should turn off
6) if it doesnt, repeat steps 2-5 with the next code on the list
hope this helps
SOURCE: Philips Magnavox MRU2600 Remote Control with RCA TV (cable)
0704,0002,0406,0007,0011,0611,0811,0312,0514,0720,0102, 0502,0601
08 17,0917,0835,0901,0103,0803,0211,0912,0114,0519,0320,0420
Estos son todos buena suerte.,
SOURCE: Need a code for a VCR/DVD player for my universal remote
Magnavox VCR. The Phillips universal remote lists the following codes:0330, 0430, 0534, 0324, 0224, 0124, 0247, 0230, 0125, 0093, 0598, 0830. Doesn't seem they have much control of which code gets used on which model. Start in the middle and work both ways to the ends. Make sure to post back which one you find that works.
SOURCE: Trying to find programming instructions and codes.
Ok I just got a new universal remote so I have a paper with all the codes. For the Brooksonic the code is 0932 and to program it press the set up button on the top of the remote, then press either the TV, DVD, or VCR button (which ever one you want to use) and then enter the code in. It should work, but I have been trying to program mine for a while now and I cant get it to work, so if anyone can help me out that would be great. I have the code to mine and the instructions, I just cant get it to work!
