Question about Campbell Hausfeld PW2102 Gas Pressure Washer
PW1345 Campbell Hausfeld Won't run
Connected the water hose & outlet hose to washer, turned it on. Machine ran for about 5 seconds then quit. Now it won't run again.
Could it be wiring ?? Sensor for pressure ?? What LL
Thanks for your help.
Larry P
    Problem Solver:
  • 11 Answers
Most electric pressure washers have a GFCI plug...could yours be tripped? If so, look for and press the "reset" button. Also, many electric pressure washers have a pressure switch that stops the motor whenever the pressure is high AND not being used. In these models just pressing the wand trigger for a few seconds will start the motor again. It will cycle off when it's not being used and on when it is.
Posted on Mar 20, 2014
    Sergeant:
  • 384 Answers
Got gas?
Posted on Jul 22, 2009
What do i do to get it to start working?
i assume you put gas and pulled the rope an its running
and have water connected and running
if all is running an water is on an the pumps not pulling then the pump is frozen
May 03, 2015 | Garden
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
Solutions won't feed from bottles on machine? I use the switch on this machine to use a deck cleaning solution and the bottles won't feed the solution into the water.
I have a SIMONIZ S2000 electric. I bought the unit about 8 weeks ago used it once. On the second use yesterday the unit didn't work as well, the pressure seemed only a bit better than hose pressure and soap did not dispense at any pressure. SO.... after much thought I turned the hose/tap pressure down so that I only got about 2-3 GPM instead of the typical 5-6GPM normally coming out of my hose....... it worked! Soap dispenses and spay is way better! It seems that if if the inlet hose pressure is high the pump doesn't work as well... go figure.
Jun 25, 2010 | Campbell Hausfeld 1800 PSI Electric...
Can't find a part #
http://www.chpower.com/webapp/wcs/stores/servlet/chCat_10051_10001_10661_-1
service center, find a part. write inlet outlet valve
May 15, 2010 | Campbell Hausfeld Airless Spray Guns &...
Hausfield Campbell pressure washer 2300 psi .Water not flowing through hose to gun
hi try statring the machine with no hose on, if ok add the hose to the machine without the gun and lance. then try the gun on its own WITHOUT THE NOZZEL in the lance. just elimate things regards
Jan 23, 2010 | Campbell Hausfeld PW2575 Pressure Washer
C/H 1750 Washer will not start with water connected. Electric motor will start without water connected.
HI I would think that your pressure switch has stuck.
You will need to remove the covers etc and check the internal pressure switch that will be situated on the outlet of the pump. It maybe stuck and just want greasing etc or may need replaceing.
Oct 30, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Campbell Hausfeld PW1380 Pump won't run when water hose is connec
http://www.ppe-pressure-washer-parts.com/campbell-hausfeld-pw138000-pressure-washer-parts
Hope this helps. I have the same problem. It's not the switch but the mechanism that slides inside the switch, which activates the switch to go on and off. I fnally found it so hopefully they have the part in stock. It's not a clogged wand trust me I have torn it completley apart and found out it is the mechanism in the switch is plastic and breaks.
May 19, 2009 | Campbell Hausfeld 1,350 Psi Electric...
Campbell Hausfeld PW2102 Gas Pressure Washer Logo
847 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
