Question about Haier hwr10xc6 Air Conditioner
Our air conditioner always ices up. - Haier hwr10xc6 Air Conditioner
    President:
  • 2,976 Answers
3 things will cause this. Trying to cool too large an area for the size of the unit, trying to cool an area too fast & dirty fins. Match the BTU's to the square footace (based on an 8' ceiling), Run it on low speed most of the time. Keep it on, even when not using it, if you will use it daily. Shut off the unit and spray the fins with Windex and then spray with plain water to rinse.
Posted on Jul 22, 2009
Air conditioner icing over
Icing is almost always caused by one or both of two situations. Either low airflow due to clogged filter or evaporator and/or or low on refrigerant. If the filter and the evaporator (the radiator looking coil right inside the case) look clean, then the unit probably has a leak and has lost refrigerant.
May 12, 2014 | Heating & Cooling
Iced up coils
Iced up coils always means a lack of heat load on that coil. This may be due to fan failure, dirty blades on the fan or "squirrel cage", dirty air filter. If the outdoor coil in a heat pump application is iced over, possibilities are: fan failure, dirty fan blades, outdoor ambient temperature too low, or failed defrost timer or ice sensor.
Nov 07, 2013 | Heating & Cooling
Indoor ac coils have ice build up and not cooling the house. can i melt it away with a hair dryer?
I have found that hot water cuts the ice better, my question to you, is why is the coil ice up?
Setting the temp to low below 72 degrees, a dirty air filter or coil, closed vents, I always have to ask is the outdoor coil clean?
Jul 12, 2011 | Heating & Cooling
I need help my unit keeps frezzin up it always get ice on it i have to turn it off for a while to let it defrost thick sheet of ice y is this happening and how can i fix this
Either the filter is plugged up and the air flow is reduced or the unit is low on freon and has a leak...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 14, 2010 | Samsung AW0803B Air Conditioner
I have an LG 110 volt model-LWHD1200FR this is the 2nd summer we have used it and have always kept thermostat set to 60 deg. The last couple weeks the front coils have been caked with ice, what would cause...
Clean both the cond and evap coils if they don't let the air through
that can cause icing
Check for strong air flow front and rear
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | LG Electronic Window Air Conditioner
Cooling fins surrounding coils are freezing and
mcdevito75 here, Possibly, the filter needs cleaning / replacement, unit set to too cold. Shut A/C off, let the ice melt on it"s own DO NOT REMOVE ICE YOURSELF, those coils have the fren gas in them, when the ice is all melted restart unit, set temp. not so cold, around 60--65 degrees, and have exhaust to out. This shpoul;d help, you can always check with your local A/C repair shop, they come to the house.
Jun 25, 2010 | LG Electronic Window Air Conditioner
Ice is forming on coil fins
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
May 19, 2010 | LG Heat cool Window Air Conditioner
Water Leaking
Dear Customer,
The likely reasons for a leaking AC are...
1) Improperly installed.
A window air conditioner must be slightly lower at the rear than the front. This allows the water being removed from the room to drain to the back of the machine. A difference of one inch is sufficient. This is always the first thing to check. Many are improperly installed in the haste to get relief from the heat. If installed too low at front the water will flow into the room rather than outside. If installed too low at rear, water can roll out front edges before has chance to exit towards rear drain.
  1. Icing up.
    Water being de-humidified can turn to ice if there are problems with the cooling system. There are many reasons for an air conditioner to produce ice. Remove front grille while machine is operating. If ice is present on the cooling coil you will probably need service. For more information see our other article: Why window Air Conditioners Ice up.
  1. Air leakage around air conditioner.
    If warm air is able to enter around the air conditioner it will encounter cooler, dryer air. When they meet condensation will occur. If water leaking from front of air conditioner inspect to see if dripping from body of machine, or water droplets clinging to front area. To test, operate machine for 30 minutes and then use flashlight to check under front edge of base. Small water droplets here indicate an air leakage problem. Add foam insulation to stop warm air from infiltrating.
  1. Drain hole blocked.
    Rear of air conditioner base has a drain hole or groove to allow water to escape. If becomes blocked water can back up. To test, operate machine for 30 minutes and then inspect if draining properly. If appears blocked use a small piece of wood to open drain hole at rear of metal base. CAUTION: Never be tempted to drill holes into the air conditioner body to relieve water pooling. Severe damage can result.
  1. Internal drains blocked.
    There are small passageways that allow water to drain from front of air conditioner to the rear. If they become blocked water will pool at front of machine and overflow onto floor. If this happens the air conditioner will require removal from window and servicing.
  1. Outside temperature too cold.
    This occurs at end of cooling season. If outside temperatures drops below 60 degrees Fahrenheit at night the cooling coil may ice up. If no leakage at bedtime but water in front of machine in morning, suspect this problem. If this problem suspected turn off machine before bedtime and restart as day warms. Alternately, operate machine at night with selector switch in ‘fan only’ position. This will circulate room air during night but not allow cooling.
Hope u find this useful. I'll be thankful if u could rate this. thank you.
Jul 10, 2008 | Samsung AW0505M Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
108 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
