SOURCE: coffee maker doesn't brew anymore
I had the same problem. I read this article and was able to figure it out the probem: http://home.howstuffworks.com/coffee-maker.htm The one way valve and the heater pipe in the bottom of the unit are extremely calcified. I opened the bottom by removing the four little "security" screws. I used a little tiny flathead screwdriver because I didn't have the proper "star security screwdriver and it worked fine. Next, I removed the two orange hoses and soaked them in white vineager. The shorter intake hose contains the one way valve. make a note of which way you remove this hose 'cause it has to go back in in the same direction. Next I propped the unit on its side so that I could put some vineager in the heater pipe and let it soak in there. Next I blew into and sucked air out of the one way hose and then rinsed both hoses thoroughly. Then I used a little piece of a wire coat hanger to scrape out some of the junk in the heater pipe, (especially on the heat side) followed by a little pipe cleaner to get it extra clean. Then I put it all back together. Be carefull that the hoses are sealed ok. I actually cut a little off of them to get a new seal on the side that connects to the heater pipe. There wasn't much room for error though. After getting it all back together I ran a few full pots through it of 1/2 vineager 1/2 water and then a couple of just water. Probably a good time to change the water filter inside the unit too. Also, from now on I'll make sure to use the self cleaning mode more often. Good luck. Kevin
SOURCE: keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
SOURCE: Water keeps dripping after it dispenses water thru the door
When you push the button, the CLICK you hear when the water flows is the Water delivery solenoid opening to let water thru, then snapping shut when U R done. The Spring is weak (prob wrong type, size, strength at factory) or the valve seal is cracked, torn, hardened or crushed.
Since all this is inside the door, you will either have to take it apart to see/fix/replace.
Quick fix: turn down the water pressure coming in(?)
Call Mr. Handyman to fix.
If under warranty - they might fix this for you for free
If this is a factory defect, there might be a recall in place for repair/replacement parts
Googlee both - Make/Model + Dripping Valve + Recall
Good Luck!
SOURCE: vaper primer gun has intermittent air supply
Does it come with instructions? The material thickness is VERY IMPORTANT when choozing the proper nozzle.
SOURCE: my coffee maker will only dispense a half of cup
Descale every 3 months if you dont then you may need to descale more than once to get it clean
