Question about Maytag SAV515DE Top Load Washer
Maytag doesn't seem to rinse.
I have a two year old Maytag SAV515DEWW that will go through the entire cycle on the dial but when you open the top at the end there is still water and suds in the machine (smell of bleach too if used). I can get the washer to drain by manually turning it around to "spin". It will spin and drain but I don't think it is rinsing at all.
Any help would be greatly appreciated.
  • Anonymous Dec 30, 2007
    Yep same issue here..this will happen almost every cycle for a month or so then magically start working again until some time later...
    Scholar:
  • 196 Answers
Try this. Run the machine set for full load, short wash. DO NOT put clothes or detergeants in the tub. Water only. Let the machine agitate for 1-2 minutes. Gently advance the timer manually untill it locks into spin. Let the machine continue to spin until it stops on its' own and begins to refill. At this point lift the lid and see if there is any access water in the tub.
Most of the time this condition is caused by a blackage in the drain line. Make sure the drain hose is not kinked in any way.
Also, there are times when I've had to removes socks and other objects from the tub to pump hose. It only take a 10% block to cause the machine to retain water.
Posted on Jan 08, 2008
Maytag centennial washer
Most likely pressure sensing switch. What is your model #? If your model has this part # W10292584 then it is the problem.
Nov 11, 2017 | Washing Machines
When water filling before cycle starts, leaking coming below top lid of overall machine on left side only. however, when testing using the rinse cycle, no leaking
I had this problem with my old Maytag (top-load) - it was the injector - an assembly mounted on the top left of the machine - a $10 fix (about $36 for the entire assembly) and the problem disappeared!_906.jpg
Jan 20, 2011 | Maytag LAT2600A Top Load Washer
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Maytag Dishwasher Will Not Rinse
You are probably not getting enough water into the machine. Replace water inlet valve (solenoid valve) and this should solve the problem.
Nov 13, 2008 | Maytag MDB7100AWB Dishwasher
Runs great stuck on rinse cycle
Peace,
ngafm to your rescue,
Yes it is in the dial and mechanism of the timer!
Things wear out! So is life!
Only a trained laundry tech can make the electronic diagnoses.
How old is the washer?Sounds old!
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Sep 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis washing machine
Yes there is a small motor just like in most wall clocks the gears strip or the gear bushing slips and refuses to advance the dial.
you have to replace the whole timer unless you know MacGyver microsurgery
Feb 13, 2008 | Maytag Atlantis MAV9750A Top Load Washer
Maytag Neptune Top Load Washer - Rinse Cycle won't run - Machine says nF
Sounds like the 'Wash water' is not pumping out fully,You need to drain the water by lowering the empty hose into a bowl & check the pump for a blockage ( if the pump is an 'electric one' check that it is working). TURN POWER OFF FIRST
Oct 25, 2007 | Washing Machines
Open Questions:
Maytag SAV515DE Top Load Washer Logo
280 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
