Question about Whirlpool Duet GHW9150P Front Load Washer
Washer leaking from door area - Whirlpool Duet GHW9150P Front Load Washer
  • 5,911 Answers
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you.
Posted on Jul 22, 2009
Is repair time and parts extensive for this type of repair? Kenmore Front Load Model# 110.45986401
Confirm that it is not the door seal. The door seal can easily be replaced and the parts are available.
You would expect that any water leaking around the door seal would migrate down to the lowest part of the tub leaving the appearance that the leak is where the two half's of the tub are joined by the retaining clips
Replacing the seal between the two tub half's is a different story as compared to the door seal. The tub seal is definitely do-able, but not for the faint of heart!!
Washer Tub Seal Replacement Frigidaire Front Load Washing Machine Repair...
If the leak is very very small I might wait until a major overall is require such as the tub seal/bearing. If I chose to wait I would monitor the situation.
Inspect the area at the hub of the pulley looking for streaks of rust.. If there is an indication that water is leaking past the basket tub seal than doing an over hall now may included front door seal, tub seal, bearing and basket seal replacement.
Dec 30, 2015 | Washing Machines
Washer leaks
There is also a discharge lint filter on the front lower left that has to seal properly. If the water appears only when washing, you can probably eliminate leaking from the water supply side up to the solenoids controlling the water. The most likely source is a leak in the rubber section between the tub and the front door, a leak in the seal between the door and the washer, a leak or overflow in the soap dispenser, or a leak in the discharge side components. You could probably figure out the source if you could view these areas during a cycle, but that would require some disassembly of the cabinet so that you would need to know what you were doing.
Jul 13, 2014 | LG WM2101H Front Load Washer
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
My inglis front loader washer is leaking at bottom of the door....inside rubber area near leak feels gummy....any advice??
Scrub the glass on your door and the rubber boot. This works in almost every case. The washer gets a build up of scum on these parts and doesn,t allow a tight seal. In rare instances you have to replace the rubber boot. Good Luck, Appliance Specialists.
Jan 04, 2010 | Whirlpool Inglis IP4400 Washer
Front loader washer leaks from bottom center of door osmetimes
Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaks water
If this leak is coming from the front door, replace the door and drum seal. If this leak is coming from the bottom or rear bottom area, this will be a loose drain hose or, faulty inlet water valve assembly connection.
Inspect these areas closely.
Jun 25, 2009 | Kenmore Washing Machines
I have a kenmore front load washer model number 4174104200 and water is leaking onto floor.
Can you describe WHERE the leak may be coming from? If the leak is coming from the front area of the washer, it may be the door bellow (rubber gasket), or the drain pump. You will need to open the door and pull back the folds in the rubber gasket and inspect for cracks or tears in the rubber. To inspect the pump, you need to remove the bottom panel under the door and look for any leaks inside the unit. The drain pump is in the front, directly under the wash tub. Also check all hose connections. If the washer is leaking from the rear area, check the fill hoses and drain hoses for cracks or holes. Make sure all hose connections are tight. The fill valve is another possiblity too. You will need to remove the top panel to view the valve to ensure it is not dripping. Please verify your symptoms and let me know. I hope this helps.
May 01, 2009 | Washing Machines
Water leaking from the door and front panel of my Duet washer
Check the rubber door seal, sounds like its split which is common after 2-3 years use.
You can find the general area of the leak by placing dry newspaper on a dry floor beneath the machine.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dish washer door leaks
This sounds like a case of the water rising too high in the machine. If your unit has a float to control the water level (located in the wash area), it is likely stuck. Free it by letting water into the machine and then exercising it to get the 'goo' out. If it has a pressure switch located in the motor area, clean out the line.
Feb 10, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Whirlpool Duet GHW9150P Front Load Washer Logo
329 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
