Question about Motorola Mobility RAZR V3
Overheating of razor phone
My phone got so hot while charging in my car that it burned a narrow 3" long hole in the seat cover of my Lexus. Talk about an expensive phone. This was the second time it has overheated and US Cellular fixed it both times, no charge. In fact, the second time there wasn't even a record of the repair. Are they trying to hide something?
    Problem Solver:
  • 14 Answers
The v3 is known for battery issues. not charging, not holding charge and overheating. my suggesting is get a different model phone. and stay away from razors. they all have battery issues, I know this from multiple customer razor issues. all battery issues.
Posted on Jul 22, 2009
My nextbook tablet battery gets so hot it burned the back cover very hot to the touch how do i fix this
Make sure that you are using the correct charger and if you are, your battery needs to be replaced. Overheating while charging or heavy use is a sign that it is near the end of the useful life.
Jul 23, 2016 | Nextbook Tablets & eReaders
Wood boss exhaust leaking
spark screen plugged?
Aug 15, 2014 | Stihl Garden
1995 Lexus gs300 power windows
check inside the boot where the drivers door swings .
the wires sometimes break inside the boot because of the
drivers door being used the most.Just **** the cover with a razor
blade and check it out.If there is a broken one (or 2) it's best
to pull the harness but you can use a **** connector or solder and tape
but it's a tight squeeze.
Best guess ,odd problem.
Jul 23, 2012 | 1995 Lexus GS 300
2001 mitsubishi montero limited light on service engine soon 110000 milege burning smell from engine oil ok transmission oil ok coolant ok
look hard around your valve cover or your spark plugs holes especially #3 and #5. i found mine on 3 and 5 spark plugs. oil sometimes drip down to hot eng and smell like burn oil. possibility your valve cover that seal your spark plug hole is worn out and leak around the valve cover and straight down to hot area. replacing valve cover gasket is not easy and if you take it shop will cost you over $1000.00 because of intake manifold and a lots of hardwares to remove. shop around before you take it to the shop. if you do it your self with a friend make sure you take picture for every lines ,bolts sensor plugs and so on you remove. also may as well tune up or change your spark plugs. good luck
Aug 26, 2010 | 2001 Mitsubishi Montero
96 lexus es300--can fuel pump be replaced thru trunk floor?
Yes, you need to remover the rear seat cushion and then remove the service hole cover.
Jul 27, 2009 | 1996 Lexus ES 300
I am trying to put seat covers on my back seats in my 1992 lexus
place a crowbar under the seats near the carpet and, pry up gently the car has clips under both sides of the center seats then: push down on the top of the seat back disengaging it
Apr 22, 2009 | 1992 Lexus Ls 400
Oil in the spark plugs
Hi, this solution will be useful to you. Your engine is burning oil. That in trurn, your engine has worn valve guide. Piston rings an engine that burns lot oil so it needs to be repaired. You have to do valve job and new set of rings.
Hasan Basha Khaleel.
Sep 12, 2008 | 1994 Lexus GS 300
Finding a back for my motorola razor 3
why not try the moto service centre itself.??.frm where u wud have bought the mob from.
Have a nice day!
tc
Jun 08, 2008 | Motorola Mobility RAZR V3
Razor v3 new battery charge problem
GUEST - replaced the battery if the phone still gets hot then you need to replaced the phone.
Eror08 - change the battery try that first
Jun 05, 2008 | Motorola Mobility RAZR V3
Razor phone don't charge
you may have some junk in the connectors of your phone pluggin or the charger clean it with an eraser the square kind, see if the pins are bent other wise you may not have the right charger or a bad one and you should probably get a new one.
Mar 20, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
405 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
