Question about Kensington K64325 Trackball
Scroll ring intermittent / non functioal
I've own 2 Kensington K64325 Trackball's. They both lost scroll wheel functionality just after the warranty period. (go figure!) The first one never scrolls, the second one intermittently, possibly on the way out? I've googled for anyone else that may have this problem with no hits. Anyways, I work in an electronics environment, and the circuit board, IR sensors are clean and unobstructed. It just seems strange that I am the only person to get 2 bad trackballs with the same problem.. oh yeah, I also tried both USB and PS2 connections.
Specs: XP / 2G ram / 2 Tb disk space / E6850 CPU....
same problem follows when connected to other computers.
Any assistance would be appreciated Thanks ahead.
  • 2 more comments
  • Rithas Dec 16, 2007
    Im having a similar issue but instead of no functionality I get altered function.  From time to time it will 'switch' to horizontal scrolling instead of vertical scrolling.  I have tried support through Kensington but so far they have done the standard clean and reinstall bit.  There is no switch in mouseworks that changes the default scroll direction.  I really dont want to have to reinstall drivers everytime this happens.
  • Anonymous Jun 29, 2008
    Same problem. Had the device for a couple of months. Opened it up & things look OK. Sounds like they have a design or QA problem.
  • pchang Oct 08, 2008
    Same problem. Sometimes the ring works, sometimes it makes no effect, and occasionally the window scrolls up when the mouse scrolls down. Mysterious.
  • mmcginity Mar 25, 2009
    I think there are possibly two different problems one can have with scrolling:
    The first is the enabling/disabling of "Allow Horizontal Scroll". This switches between vertical and horizontal scrolling with the scroll ring.
    The best thing is to map some key-combination (me, I use buttons 4+ 5) to toggle this option.
    However, I have a second problem with one of my trackballs (I have two)...
    the scroll ring itself seems to be producing noisy data. When I scroll vertically, the whole scrolling motion is extremely jerky and noisy, sometimes jumping up and down large amounts rapidly. I know this is not normal behaviour because my other trackball behaves perfectly.
    My intuition is that this really is a hardware fault.
I have a similar symptom, that is, apparent loss of scroll ring functionality as homercles1 noted, but in fact the scroll ring functionality gets toggled between horizontal scrolling and vertical scrolling as Rithas has noted. A window that is not wide enough to require horizontal scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in horizontal scroll mode. Likewise, a window that is not tall enough to require vertical scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in vertical scroll mode.
Solution that worked for me:
My upper right-hand button is defined as "Allow Horizontal Scroll" and by clicking this button, the scroll ring function toggles between horizontal and vertical scrolling. In fact, what can appear to be a nonfunctional scroll ring in some windows is very useful when moving around in large windows.
Hope this comment will be useful to you.
Posted on Jan 21, 2008
Scroll is hesitating.. Will work for moment then button keeps scrolling but screen does not scroll with movement of button... Can this be fixed or do I have to replace?
You can try a few things... Take a clean rag or cloth and moisten it with rubbing alcohol and gently scrub across the scroll wheel to remove dirt and skin oils from the scroll wheel and trackball. Don't let alcohol drip into the trackball body. If that doesn't work, and you are somewhat mechanically inclined, you can turn the trackball over and remove the screws that hold the housing together (some may be under the rubber pads on the bottom of the trackball) open the housing and clean the parts that contact the trackball and scroll wheel with a clean rag or cloth. Blow out any dust or dirt in the housing, Dry the parts you cleaned with alcohol and reassemble the trackball. Use rubber cement on the rubber pads, not model cement or super glue, in case you need to disassemble the trackball again at a later time.
Aug 16, 2013 | Kensington TurboBall (64227) Trackball
Need to download kensington 64325 driver mac
you can install the driver by following this link.
Oct 19, 2012 | Kensington K64325 Expert Mouse, DiamondEye...
I need the documentation for this mouse. Where can I go?
just go this website..............
ull get the documentation
Jun 26, 2010 | Kensington Expert Mouse Pro Trackball
The tiny red ball bearing got lost, what could be used as a replacement?
Kensington took its time bringing an optical version of its venerable Turbo Mouse to market. The Turbo Mouse was the original multi-button ADB trackball, introduced back in the late 1980s with two buttons and evolving through the late 1990s into a four-button, do-everything wunderkind of a mouse. Unfortunately, Kensington didn’t rush to produce a USB version once the iMac hit the market, leaving users stuck with the imperfect solution of a USB-ADB converter or—heaven forbid—even worse, the stock iMac mouse. Finally, when it got a USB version to market, the rest of the market had moved on to the optical mouse, and Kensington’s renamed Expert Mouse was behind the times again.
No longer.
expert-mouse.gif The latest revision of the Expert Mouse, version 7.0, has been out for about a year, and it fully lives up to its billing as the “ultimate trackball.” With USB connectivity, optical tracking, four programmable buttons, a brilliantly conceived “Scroll Ring,” an included wrist rest, and a billiard-size trackball, this mouse is the whole package.
Let’s get one thing out of the way: the Expert Mouse is the epitome of all things trackball. It’s the latest offspring of the original trackball mouse. If you’re a trackball-hater, approach this review with an open mind. Don’t hate the player. Hate the game—and Kensington’s game is not to be hated lightly.
A good mouse starts off with one of two things: either it’s dead simple or it has great software. Apple has always taken the dead-simple route. Kensington takes the opposite tack, with incredible software that makes an otherwise complex mouse quite easy to use.
Software has traditionally been a Kensington strong point, and the latest version of MouseWorks for Mac OS X is no exception. The only drawback is that third-party mouse support has disappeared. (A little-known secret on the Classic Mac OS was the fact that Kensington’s ADB MouseWorks software was amazingly supportive of non-Kensington devices, sort of like an ADB version of USB Overdrive.) It’s hard to find fault with Kensington for failing to re-implement this feature when it rewrote the software from scratch for Mac OS X.
expert-app-settings.gif MouseWorks will be immediately familiar to anyone who has used the Classic version, except it’s now implemented as a preference pane rather than a control panel application. Separate tabs are provided for button assignments, scrolling control, click speed, and—best of all—acceleration, which allows for a fantastic degree of fine tuning. There is excellent help and documentation, which are thankfully no longer the rarity they once were. Buttons can be assigned on a per-application basis, giving the user limitless possibilities for individual behavior in each application. This comes in especially handy for media pros, though almost every power user can, in time, make good use of it.
expert-acceleration.gif As with all good software, the default settings are sensible, too, though most folks will probably find the default scrolling speed and cursor tracking a bit too slow. Unlike Classic versions of MouseWorks, the new version bases these values on their corresponding global system preferences, so if you find yourself wanting to turn it up to eleven, make sure you’ve adjusted the settings in the Keyboard & Mouse preference pane first. Conversely, if you find it turned up to eleven and a mere tap of the mouse sends the cursor all the way across your screen, make sure the Keyboard & Mouse settings aren’t too high.
There seems to be one minor bug with the software under Mac OS X 10.3: plugging or unplugging the mouse seems to activate the screensaver within about 20 seconds. There doesn’t appear to be any rhyme or reason to this behavior, but it’s fairly reliable and happens almost every time.
Let’s move on to the mouse itself. The great benefit of this long line of trackballs has always been the size of the ball, which allows for much better cursor control than, say, the built-in trackballs on 100-series PowerBooks or the thumb-balls used on Logitech and Microsoft’s widely tolerated optical trackballs. If you’re soured on trackballs because of bad experiences with another model, rest assured this is one area where size does matter, and the Expert Mouse could well change your opinion.
expert-mouse-hand.gif The included wrist rest is a nice touch. Though wrist-rest mousepads are a dime a dozen now, the pleather-covered dense foam makes for a comfortable and stable support. Just don’t plan on taking it off. It snaps into its two mounting holes very tightly, and it’s pretty tricky to remove. The leading edge sticks up a little higher than it should, which is mildly uncomfortable. Moving your hand up on the mouse a bit helps, but doesn’t entirely avoid the problem. Of course, if you already have a wrist-rest mousepad, this should be a non-issue.
Kensington sensibly attaches a six-foot cord, putting the Expert Mouse within reach of even the worst hide-the-tower-under-the-desk setups. This cord is no longer detachable, as the ADB cable on the Turbo Mouse was, nor is there a USB pass-through on the Expert Mouse, though there’s admittedly less reason for one with the proliferation of USB hubs on the desktop. Though not tested for this review, a wireless version of the Expert Mouse (using proprietary RF, not Bluetooth, unfortunately—maybe in version 8.0?) is available for an additional $20, if you’re the type who hates any cord clutter and loves to use batteries.
Tracking is accurate and generally smooth, although not as precise as I remember the Turbo Mouse being under Mac OS 9 on my Wall Street, especially at slow tracking speeds. Fortunately, with the optical pickups, you’ll never have to worry about the ball sticking or the horrible thunking sounds the ball bearings in the old Turbo Mouse could make when dirt and dust got into the mechanism. Trust me, with heavy use, this happened more often than you might think, and the Turbo Mouse required fairly frequent cleaning. It’s one of the disadvantages of a trackball, with its upward-facing mechanism that collects whatever gravity drops on the ball.
expert-scrolling.gif Scrolling with the ring is very comfortable and feels quite natural, since my ring finger and thumb rest on or near the scroll ring anyway. It is not, however, as smooth as the tracking is. In fact, it’s noticeably jumpy at times. The scroll ring has very shallow detents that seem to exacerbate this problem, much like the soft clicking you feel on most scroll-wheel mice. At least some of the blame can be laid at the feet of application developers, though. Scrolling is noticeably smoother in Safari than in either Camino or Eudora.
Finally, those four glorious, programmable buttons are all within easy reach for maximum clickability. Even reaching over the massive trackball to chord is no problem, as your hand settles into a natural spread over the top of the mouse.
When I dropped $120 on a Turbo Mouse back in 1999, I did so sight unseen and without having tried it. Call it instinct. With the $20 price drop and superior features, the Expert Mouse is an even better value than its grandfather was, because the experience is markedly improved. While a lot of people might say $100 is too much for a mouse, a lot of people haven’t given the Expert Mouse a fair shake.
Kensington is one of the very few computer or peripheral makers to offer a fully transferable five-year warranty on anything, and their technical support has been highly praised in the rare case that it’s necessary. Do whatever you can to experience this mouse, and then try to argue it isn’t the best trackball—and maybe the best mouse—ever made. Well done, Kensington. Well done indeed.
Apr 30, 2010 | Kensington Expert Mouse Trackball
Kensington mac os x driver doesn't work
Try Step A
Unplugging it and re plugging it back in
Or if you have another mouse do step A then move the curser with the mouse and now the trackball will work
Frustrating Isn't it !
Nov 07, 2009 | Kensington Expert Mouse Trackball
Lost the Trackball any other way to scroll
no other way to scroll but the trackball it's self only costs 2-5 dollars to replace Amazon even has free shipping.
Mar 30, 2009 | RIM BlackBerry Pearl 8100
Expert Mouse scrolling problem
I have the same problem running under win7 64 bit, I have just pulled apart my expert mouse\trackball to clean it and found that the scroll ring works by using a little infrared diode ... so no cleaning required ...
the screws for the base are located under the little rubber feet.
So I think the problem may be more related to drivers\software...
at the moment I cant find a win 64bit driver or mouse works application anywhere
Feb 05, 2009 | Kensington Expert Mouse Trackball
Got new computer cant program buttons on TB
Try going into Control Panel & click on printers. Then when the window opens, click on key settings and see if you can set the buttons to what you need. You should be able to program all the buttons there. Hope this helps. Bud
Dec 23, 2008 | Kensington K64325 Trackball
Kensington K64325 Trackball Logo
535 people viewed this question
Top Kensington Computers & Internet Experts
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
