With disk in, says no disk
I know the disk I incert is good. Yet the door closes and load comes up. THen it sats no disk. All other fuctions work. Thanks
    Problem Solver:
  • 11 Answers
Open up the cover of the dvd deck hook it up to ac outlet power up and and insert the cd, have a close look as the cd is loading. If your CD spin and the there is a red light coming or flickering from the back of the CD and the spins that means it needs CRC cleaner.
IF it spins and stop after 5 secs then it the motor that needed to changed.
If no light coming from the back of the CD then it a laser broblem.
Never run the DVD with no CD on as the light coming from the laser can cause blindness.
THKS
Posted on Jul 22, 2009
I opened my laptop SONY VPCEH-32FX and saw that the Administrator Icon is gone. I tried to log into my account using the same password I always use and received a message "unable to load user profile". I...
Your computer should come with a recovery disk instead of a recovery partition, check for the disks that came with you computer or you can get one for it here
Sep 27, 2013 | Sony VAIO Computers & Internet
E305075FPSA HighSpeed Eletrolux the door appears to not be closing tight.
No! this not normal, I'am concerned about microwave leakage, and a 1/8 gap is to much, should be tight against the seal "major safety factor" the door is out of alignment or the bottom latch is not secure "to much play" I recommend a pro simply because he needs test for leakage when the door is properly fixed.
Mar 22, 2012 | Electrolux ICON Microwave Combination Oven
Incert dvd read out sats NO
Hello
This usually happens when the DVD or laser lens pick-up has become dirty.All you need to do is
1. Check the disk for scratches.
2. Make sure the disk you are using fit the correct format specified by your DVD player.
3. Clean the laser lens with a DVD laser cleaning disk.
4. Insert a correctly formatted undamaged disk into your player,listen to see if it begins to read the disk,if it continues to make no sound.
5. Open the DVD player carefully and clean the lens with isopropyl alcohol and cotton swab.
6. If none of these solutions works out then a professional repair technician will be able to tell you if fixing your DVD player is worth the money.
BEST OF LUCK
Jul 13, 2010 | Toshiba SD-K760 DVD Player
2005 Ford super duty 6 liter when I shut the truck off and pull the keys the radio power stays on along with the gagues and the check gauges light comes on. Even when I open the door everything stays on
It's suposed to stay on till you open the door even the power windows should work even with the key off and pulled the problem can be the door switch is bad unplugged or the wire to it where it goes thought the door hinge area can be broken. do any of the other door oopen and close functions work? Interior light work like it's supposed to? If not the switch may be bad but if any fuction of the switch works then it and it's wire are good. Is the check engine light on with the engine running? if it is this needs to checked out. The best way to find the problem is with a dianostic scanner in the body dianostic mode but eliminate the door switch first as they fail alot and it'll make it do it. In dianostic mode you can see all the door switches and there's one for every door and they all have to ge right and good or the system wo'nt reset corectly. The thing that can be bad and a scanner will find it is the GEM ( general electronic module ) sounds expensive? Most are less than $60 but some are bumping 200 it's find plug and play but sometimes with the scanner in acutor mode you can find a door lock motor or switch not responding and fix it and the system will then reset and it'll go back to normal. now rember I said any door switch not working, so agood reset involves window down doors closed and the hood open disconnect the battery and then lock all the doors close them good, All of them! Now conect the battery unlock the driver door with the key and then unlock it again the other door should unlock then too, if it doesn't this is on your list to fix too. The lock motors have to work or the systems door locked or unlocked switch won't know that it's still locked and the system fault will not let it work corectly. The GEM seldom fails and many are replaced and not fix the car so don't jump at it. Make the doors pass every thing first. Turn the key in the lock both sides if you have a passenger lock it has an unlock switch too, and it has to work as it reports if the door is locked or not. The remote unlocker need not work but it's nice if it does but it won't throw the system off.
Jun 08, 2010 | 2005 Ford F 250 Super Duty
Numerous probs: 1)door won't open/close (if it does open);2)can hear (intermitently) mechanisms working when equipment is off; 3)will not detect DVD
I would suspect a weak power supply. If the power supply is not giving proper voltage, or even able to maintain proper amperage, then numerous problems will occur. One of my Ilos would take forever to come out of the "Hello" screen or open the door to load, or once you got a disk in it it would not recognize the disk. You could hear this grinding noise coming from it. Any of this sound familiar? On mine the two large capacitors on the power supply board were bad. If they are swollen then change them out. Radio Shack had them when I did mine, but most electronic supply store should carry them
Jan 10, 2010 | iLO DVDR04
Camcorder will not recognize disk
make sure disc in incerted correct way, and is propper disc type, check head is clean and door is shutting corectly is all i can think can be wrong
Nov 30, 2009 | Samsung SC-DX103 DVD Camcorder
The hp director has a problem at scan it ask for a disk to be incerted. it should scan and ask for e- mail or fax what is the problem
When your printer was installed it was with a disk, its looking for that disk again so it can load a driver or dll. It wants to know where that disk is, or where the file it is looking for is located. The director will read that disk or file and load what it wants so your scan will work. In short. You need that Installation Disk. Good Luck.
Oct 29, 2008 | HP Computers & Internet
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
Legacy ld53um
Buy a cd cleaner kit, if it doesn't work have someone who know how re-align your laser eye. Goodluck.
Mar 07, 2008 | Legacy LD53UM In-Car DVD Player with 3.5"...
DVD PLAYER PROBLEM
Sounds like a common problem with this trutech brand. There are some possibilities. 1. Laser could be worn out, 2 it could be a bad cable coming from the laser. 3 The home switch for the laser to come all the way back to its "HOME" position could be bad. But usually if this is the case, the disc won't spin at all. And 4th, the spindle motor that spins the disc could be worn out. Causing the disc not to spin fast enough and thus causing an error. Let me know if you want to send me one of these anyone so as i can trouble shoot the problem further. Keep me posted and i hope this helps you out some. Thank you Jay
Oct 10, 2007 | TruTech PVS2119 19 in. LCD Television
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
