Home Logo
A
Anonymous Posted on Jan 17, 2017
I have a sterling noble Westminster mantel chime clock It runs on 1 c battery, has no back cover. Problem is I want to turn off the chimes. They are very loud and I no longer enjoy it
How to get a sterling and noble chiming clock time set
To set the time on a Sterling and Noble chiming clock, please follow these steps:
Remove the clock from the wall or mantle and place it on a flat surface.
Locate the clock's time adjustment knob. This is usually located on the back of the clock and may be labeled "Time," "Adjust," or "Set."
Turn the knob clockwise or counterclockwise to set the correct time. Be sure to move the hands of the clock in the direction of the correct time.
If your clock has a chime feature, locate the chime adjustment knob. This may also be located on the back of the clock and may be labeled "Chime," "Strike," or "Silent."
Turn the chime adjustment knob to the "Silent" position if you do not want the clock to chime. If you want the clock to chime, turn the knob to the desired chime setting.
Once you have set the time and chime settings, replace the clock on the wall or mantle.
Note: It is important to set the time accurately and synchronize it with an accurate time source, such as an atomic clock, to ensure that the clock keeps accurate time. Additionally, it is recommended to consult the clock's user manual for specific instructions and troubleshooting tips.
Strausbourg manor quartz Westminster mantel clock. Why did it stop chiming?
Source: Wikipedia
The full hour chime is followed by one strike for the number of the hour by Big Ben (E3) (one strike for one o'clock, two strikes for two o'clock, and so on). ... The mechanism then plays two complete sets of five sequences for each complete hour.
Source: PortableFireplace
Learn how to fix a mantel clock that chimes at the wrong hour. This simple fix will repair a clock that chimes at the wrong time. This can commonly occur when your mantel clock is laid down on its back and the timing is offset.
1 Thing You Have to Understand First On most clocks you can turn the minute hand counter-clockwise but SOME clocks are not safe to be turned in that direction. For this reason, it's best to only turn your minute hand clockwise just to be safe.
The Simple Mantel Clock Adjustment The easiest way to adjust a mantel clock chime is to move the hour hand to the hour that the chime is striking. Make sure that the hour hand shaft is not too tight or else it will not turn. Most mantel clock hands are friction held. DO NOT BEND YOUR HOUR HAND, loosen the shaft if it will not turn freely.
Once you have synchronized the hour hand with the hourly chime, adjust the minute hand to set the clock to the correct time by moving it forward (clockwise) around the clock face. Allow the chime to strike at every quarter hour strike.
Mantel clock Chime Adjustment When your mantel clock chimes the wrong number of times, your chime is not synchronized time of the clock. To adjust your mantel clock chime, proceed with the following step:
ADJUSTING THE HOURLY CHIME
  1. When your mantel clock chimes, count the number of times it chimes. This is what time your hourly striker is set to.
  2. Move the hour hand to the hour indicated by the hourly chime (count the number of gongs at the hour).
  3. Reset the time using the minute hand to the correct hour and the chime should adjust along with the clock hands as well.
ADJUSTING THE QUARTER CHIME
On most mantel clocks, you can simple remove the minute hand which is friction fit. You have to apply pressure on the tube and it will loosen. Once removed, re-install the minute hand at the correct time. From there you can rotate the minute hand to reset the time.
Mar 17, 2021 • Home
2answers
How do I stop the continuous hour chimes on a WESTMINSTER chime mantel clock ?
Is this a older type mantel clock or an electric. A older one has a small arm on the back of the wooden case just move it to it's opposite position and that should stop all chimes. A few times that small switch is on the inside but very rear. If it's electric it also should have a switch to turn off all chimes.
Feb 06, 2015 • Home
Setting Westminster chimes in bulova mantel clock
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
http://usedclockparts.com/8-clock-movement-repairs/14-fix-a-clock-that-gongs-wrong
5helpful
3answers
Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
The time and chimes are out of sync for our tempus fugit wall clock by 4 chimes does any know how to adjust it
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
4helpful
3answers
I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMINSTER LINDEN MANTEL CHIME CLOCK
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
1helpful
Whitting and Westminster Jean luis Electronic clock
I found my own solution through trial and error. I set the dials to 12 00 and then move the dials to show just over 5 minuites to 12 ( 1155) the alarm melody start and chimes for a number ( in may case it was one.) then i moved the dial back to 1200 and then reset it again to 1155 or just over. Each time the alarm chimes an increasing number
I had the clock chime settings on the back of the clock to the middle setting (chimes on 24 hours)
I carried out this until the chime was right for the time i was working ( in my case it was 1730) so when it reached 5 chines I then set proper time and left it. The next chime was correct
Top Sterling Home Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
ADMIN Eric
ADMIN Eric
Are you a Sterling Home Expert? Answer questions, earn points and help others
