Question about Canon PowerShot G2 Digital Camera
On f4 to f8 I am getting a dark blurr on pictures, but not below
It is in the same place every time, and it increases in density as I increase the f stops... I think it might be a speck of dust on the inside lens (having cleaned the outside)... the camera is a G2 and therefore is NOT an SLR so the lens does not come off easily, and quite frankly I don't think it can be done by someone other than a tech... looks like a special tool is needed... has anyone else experienced this problem besides myself and the other guy, with his white spot...
eventually I will get the cash to have it taken to a tech, but in the meantime I am still taking some great pics under duress ;(
I'm having a similar problem with my G2. It happened after I took somephotos when it was snowing. I think some moisture may have got on thesensor and left stuff on it. I don't think it is the lens that iscausing it, as this can never leave this kind of smudge. I stillhaven't got round to doing anything about it.. I would be interested tohear how you got on with getting it repaired.
I found this article which confirms what you were saying about thehigher f-stops (and also provides and explanation). I have also checkedthe EXIF data on my photos and found that there is a correlation withhigher f-stops and degree of blur (with very little to no blur at thelower f-stop values).
http://dgely.com/Phototips/Digital_Camera_Sensor_Cleaning.htm
Posted on Dec 30, 2009
HOW TO INCREASE DARKNESS IN HP 4300
1. If you are printing using postscript driver, try using PCL6 - printout would be darker for grey scaled items.
2. Print in lower resolution 600dpi or 300dpi, printouts would be darker.
3. Try printing all characters as black
You can adjust darkness at the printer using the console menu.
In the Configuration Menu ' Print Quality sub Menu , there is a parameter called Tonor Density. Factory Default is 3. Set to 4 or 5 to increase darkness..
Sep 27, 2013 | Office Equipment & Supplies
Tip
How to use F1, F2 ?..Function buttons on Hp laptop.
For those who do not know how to use the F1, F2, F3..... buttons on HP laptops, here is an opportunity for you to know.
We see these buttons on most laptops but don't know what they are used for. F1, F2....... buttons are the first set of buttons on the keyboard. These buttons makes it easy for anyone to access some programs on the computer without using mouse.
Follow the below procedures on how to use some of these functions:
To put your HP laptop on sleep mode, Press and hold Fn button on your keyboard, (without leaving it) then press F5 (Fn + F4).
To lock your HP laptop, Press and hold, Fn button, then press F6 (Fn + F6).
To reduce the brightness of your HP laptop, press and hold Fn button, then press F7 (Fn + F7).
To increase the brightness of your HP laptop, Press and hold Fn button, then press F8 (Fn + F8).
To put your laptop on mute, Press and hold Fn button, then press F9 (Fn + F8).
To reduce the volume of your HP laptop, Press and hold Fn button, then press F11 (Fn + F11).
To increase the volume of your HP laptop, Press and hold Fn button, then press F12 (Fn + F12).
To shut down your laptop or to view other shut down options, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
To close any page on your HP laptop, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
Good luck.
on Nov 06, 2010 | Computers & Internet
How to increase brightness without fn+f6 keys because for now the f6 key is not working
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
Oct 08, 2012 | ASUS EeePC1000 1000H 1000HA 1000HC 1000HD...
I did not get any instructions with my Opteka. Have tried to take photos with it. But they came out all blank. I used a tripod. Would like to know where I can down load instructions. Certainly not as good...
You did not provide enough information to determine what your problem is. For example, were the pictures all light or all dark. Knowing this lens, I will assume that they were all dark. So...
1) This is a very, very slow manual-focus lens. It will not auto focus. It must be manually focused very precisely because it has virtually no depth of field.
2) Depending on your camera, your internal light meter may not work. On my camera (Nikon D-90), it does. If it does not on yours and I suspect that may be your problem, you're going to have to shoot everything manually, i.e. setting the shutter speed and lens opening yourself. You can use your internal light meter to help you get started by taking your light reading before you install the lens...preferably using the aperture only setting where you set the aperture at f8 which I think is the speed of the Opteka and let the camera set the shutter speed. Make a note of the shutter speed then attach the Opteka to the camera and mount the lens on a tripod with the camera attached.
Then set your camera mode to manual and set the aperture to match the lens (f8, I think). Set the shutter speed at the speed you noted earlier. Shoot a picture using a remote shutter release or the self timer. This lens is so slow that unless you're in exceptionally bright conditions you will get fuzzy pictures due to camera movement at full zoom of 1200m and above if you're using the 2X doubler. I would start shooting at minimum zoom of 650 without the 2X doubler. Shoot a picture. and check the result.
You should have an image but it may be too light or too dark.
If its too light you'll need to increase the shutter speed or stop down the aperture to, say, f11...or both. Make the adjustment and shoot another picture. Remember that if you increase the aperture, you increase your depth of field, making focus less critical. If you increase the shutter speed you make camera or subject movement less critical.
If it's too dark, you can only increase the shutter speed because you can't open the lens any wider than f8. Make the adjustment and shoot the picture.
Keep doing this until the pictures are the way you want them.
This is a decent lens for the price and worth the little money they cost if you can't afford $10,000 plus for a high quality telephoto lens of this size. I would forget about the 2X doubler because as others have said, it further reduces the speed of an already very slow lens with such a high rate of magnification that a knat landing on the lens could cause the picture to blur from movement.
Jun 26, 2011 | Opteka 650-2600mm High Definition...
I got a ADVENT Modena M201 Laptop and I know how to turn the webcam on but there's no programme on the 'all programs' tab for it. When my friends are round I would like to take pictures with them but its...
Below please find key - function overview.
Fn + F7 will turn on/off the webcam
It might help you.
Function Keys Fn+F1 - Places the computer into sleep mode
Fn+F2 - Changes the (I-Powerxross) power settings
Fn+F3 - Switches display modes: LCD only, External monitor only, LCD+External Monitor
Fn+F4 - Turns Wireless LAN on/off
Fn+F5 - Switches OSD (on screen display) on/off
Fn+F6 - Turns the Touchpad on/off
Fn+F7 - Turns the Webcam on/off
Fn+F8 - Mute Sound
Fn+F9 - Reduces speaker volume
Fn+F10 - Increases speaker volume
Fn+F11 - Reduces the screen brightness
Fn+F12 - Increases the screen brightness
Fn+Esc - Toggles Bluetooth & 3G on/off (optional)
Feb 27, 2011 | Computers & Internet
The screen on my laptop is very dark can u tell me what settinggs to brighten it up please ???
you have come to the right place. you will get anwsers to all your problems at fixya. if you want to brightening the screen of the laptop, the combination of the keys below will help you out.
Fn + F7 - Increase Brightness
Fn + F8 - Decrease Brightness
Feb 16, 2011 | Advent Netbook
Dark pictures at times on auto is there a fix? Camera Fuji s1000
when you think that there is less light or whn you are taking a picture indoors or during night times under auto then reduce the ISO acordingly like if the lighting is of the indoor lighting then you can place the ISO at 80-200
if outdoor and during night time 80 or below and so on depending on the light conditions
the lower the light the lower the ISO
this would increase the shutter time though improving exposure quality
happy clicking
Jul 14, 2009 | Fuji FinePix S1000FD Digital Camera
Blurr and dark pictures, ISO setting at highest, TV mode,
the picture are blurred because you use probably a tele lens, you need a pod. Picture are darkbecause there is not enough light. increase time (you need a pod)
Jan 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Brother HL 1440 Printer Density Adjustment
For sure u can increase the darkness and there are settings to increase but u need to browse through the menu to locate the darkness increasing options. The mannual should definitely help.
Thanks
Feb 08, 2008 | Brother HL 1440 Laser Printer
Canon PowerShot G2 Digital Camera Logo
64 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
