Question about Indesit W 123 Front Load Washer
My maytag model LA712 won't drain what should i do? it spins but wont drain.
    President:
  • 1,776 Answers
This is usually caused by an obstruction in the main drain line. Sometimes a small piece of clothing, like a sock, can get between the clothes tub and the outer tub that holds the water. If this happens, the piece of clothing can get into the main drain line or the pump itself and clog it up. Check the large diameter black hose that is attached to the pump and look for an obstruction. If you find something, use needlenose pliers to get it dislodged.
Sometimes you can't get to the obstruction from below and you would have to remove the agitator, top of the outer drum shield, and the inner tub. This can be difficult and can require special tools that you may want to get a qualified appliance repair technician to do.
If the drain line isn't plugged, then the problem could be with the pump. The internal impeller could be broken and the pump would have to be replaced.
Sorry for your troubles and I sure hope this helped. Good luck.
Posted on Jul 22, 2009
  • Indesit Master
  • 3,361 Answers
Clean the drain pump filter.
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
MAYTAG NEPTUNE WON'T SPIN OR DRAIN
If it can't drain, it shouldn't spin. Pump blocked? Broken pump? Level sensor broken?
Sep 05, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Model LA712 washing machine has a small leak how
These washers are notorious for getting an injection bladder leak. The baldder is located atop the washer in the imlet hose assembly; here is the part:
Located here on top left hand rear corner:
Remove the injector(white pointed plastic looking thingy) from inside the old bladder and shove it up into the new bladder ; reinstall it back where it came from.
Oct 21, 2009 | Washing Machines
How to change the belts on a LA712 Maytag washer
Tell me how to get a service manual, Manual!
Anybody know where to get them or find them on the web?
Have a La712 that will not shut off the cold water whether the machine is running or not.
Sep 07, 2008 | Maytag Washing Machines
Indesit W 123 Front Load Washer Logo
223 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
