SOURCE: HP 1610, Remove Cartridge message
also replace the colour cartridge as it is not showing but the printer is not able to detect that cartridge also.many a times it solves the problem.
SOURCE: HP DeskJet 930c is leaking black ink
The printer primes and cleans the cartridges when the cartridges go to the right side of carriage. Sounds like a cartridge has either leaked or you have used it enough the the ink pool is full, or you have layed the printer on its side or back. From experence, if ink is leaking out of the printer, your probley better off getting anithe printer. I have tried to take the covers off and clean inside print, and it is a messy job.
SOURCE: HP Deskjet 3915 Printer ''Door Open''
open all the doors (fron and back) make sure there is no paper jam .
close all doors, one at a time.
turn off, wait for a few seconds,,,
turn on
and your problems is solved.
SOURCE: hp c7820 printer 02 black catridge
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expected you to have installed is not right. Double check that the ink is correct against the manual or written instructions inside the printer using the number not the shape or color of the cartridge. Not every cartridge that fits the printer necessarily works.
Open the lid of the printer. Depending on the model, there will be two cartridges on the right, one for black and one for color.
Find the cartridge that is running low on ink. The black cartridge will be in black, the color cartridge will have a patch of color (usually green) on it.
Pull down on the black clamp that is holding the cartridge in place and slide out the used cartridge.
Open the package of the new ink cartridge. Remove the protective tape and slide the new cartridge into the printer.
Snap the black protective case back into place and close the lid.
These types of severe
cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print
cartridge(s) problem", "cartridge in wrong slot", etc.) typically indicate the internal micro-electronics
of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at
rear and lower side of the ink cartridge, are very delicate and are somewhat
susceptible to ink attack over time, which can lead to premature failures. In
addition, the older the cartridge the higher the chance of an internal
electrical failure. I suggest you first run a 'Tap 41' diagnostic test to
check cartridges electrical health (this is a forced test); you may also bypass
the error (temporarily) on most models which use HP 74/75 cartridges. Refer to
Inkjet411 youtube videos below:
HP 74, 75, 74XL, 75XL
Cartridges - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart
C4200-C4500 and C5200-C5500a Printers -
Diagnostic Tap 41 Test: (verifies
electrical health of ink cartridges):
http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP
74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet
J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling &
Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
