Question about Sony PlayStation 2 Slimline Console
The game inside it spinning
The game is clean
    Problem Solver:
  • 10 Answers
So thats good
Posted on Jul 22, 2009
My disc reader motor wont spin. it refuses to read the disc
Hi,the unit needs to have the laser reader lens cleaned but DONT use regular rubbing alcohol.
Get pure stuff....the rubbing type leaves a glare on glass and plastic lenses.
Also ,the chrome rails that the laser moves along need to be cleaned and lubed with liquid silicone.
This method clears read problems most of the time.
when a disk reader refuses to spin, sometimes it might be from the motor mechanism that allows it to spin when you insert a disk inside the disk reader is damaged that's might be the reason it does not spin.
You can check both the lens and the mechanism to be such which needs to be replaced.
Take care.
Oct 08, 2010 | Nintendo GameCube Console
Wont read game
Does this happen to all discs? Then your ps2's lens might need cleaning. Run a disc cleaner and let it spin for like 30 seconds. If this does not solve the problem, then you might need to manually clean the lens inside. Take out the casing carefully, then remove the plate covering the lens. Get a swab or a qtip and damp it to alcohol. Then gently wipe the lens and let it dry. Now you can try again playing those discs.
Aug 17, 2010 | Sony PlayStation 2 Slimline Console
Game cube disc no spin cleaned disc nothing
your lens is ruined it will not work anymore have you look inside it says DO NOT TOUCH LENS!!!! you touch it thats your problem. im sorry please rate!
Apr 10, 2010 | Nintendo GameCube Console
Console does not read either film or game
I would say get a cleaning CD with the bristles on the Cd to clean the lens of the Wii. When you get it, all it does is spin in the CD tray and clean the lens inside the CD tray. That should fix your problem the lens is probably dirty. If it doesn't leave a comment and ill try to help again. If i helped please give me a high rating.
Jan 09, 2010 | Sony Playstation 3 (PS3) Console
Doesnt accept discs
try cleaning the ps2 inside and try a new game to see if its your system good luck
Jan 08, 2010 | Sony PlayStation 2 (PS2) Console
Discs not spinning.
the laser has gone bad which is why its not reading and you did all the necessary cleaning that I would have done.
Best thing is to find a laser for the ps1 or to find a broken ps1 on ebay for cheap and swap out the laser.
Dec 02, 2009 | Sony Video Game Consoles & Games
The disk isn't spinning. When tray closes, it tries to spin for a moment, but then it doesn'tt.
When you first put a CD/DVD into the Playstation 2, the disc spins enough so that the laser can read if it's a CD, DVD movie, DVD ps2 game or CD ps1 or 2 game to spin at the appropriate speed. If there is no disc inside, or the laser thinks there is no disc inside, the disc will only spin that 1/2 of a turn. So what would cause the laser to think there is no disc inside?
A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable. I would suggest using a 400C since it is a better laser [and more available] than the 400B. YES, despite anything you have read, you CAN replace a 400B with a 400C IN ALL CASES.
Jun 05, 2009 | Sony PlayStation 2 (PS2) Console
Unreadable Disc for all games?
yes you can theres two ways,
you can buy a disc cleaner thats just a normal disc with brushes on it, and it wil spin inside and clean the lense.
or you can take it apart and manually clean the lense
problem solved :)
Feb 16, 2009 | Microsoft Xbox 360 Console
Ps3 not reading cd/dvd/games/blurays
hi...
The inside of the disc player is probably dusty. Video game consoles are notorious for gathering dust. I've fixed dozens that way. Cleaning inside the drive
Jan 15, 2009 | Sony Playstation 3 (PS3) Console
Disc doesn't spin
First of all check the little trigger inside that checks to make sure the lid is closed. It won't play the disc if it thinks the cover is open. Otherwise, it sounds like the motor that spins it is probably broken and needs to be repaired / replaced.
Apr 27, 2008 | Nintendo GameCube Console
Sony PlayStation 2 Slimline Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
