Question about JEEP Wrangler Unlimited Toy Vehicle
I want to swap everything from my 88 4.0l and put it in my 86 that has a 2.8 bothare auto but the radiator is diffrant what do i need to know
  • wahhill05 Jul 22, 2009
    So use the radiator that was in the jeep.
  • 1,596 Answers
Engine Wiring Harness and ECM have to be Swaped Radiator Stays With Engine
Posted on Jul 22, 2009
I put a 94 ninja 600r engine in my 86 ninja. nearly twice the hp now but it runs to hot.i need to know the coolant capacity of a 1994 ninja 600r
try putting the radiator of the 94 motor in place of the 86 radiator or sourcing a radiator with more cores in it
Nov 15, 2015 | kawasaki Motorcycles
How do I get my alternator to charge? 86 Chrysler Fifth ave.. I've checked everything? !!!
check that the brushes are running on the rotor rings .
have the rectifier block tested check that it is connected properly
check the regulator for out put
adjust the drive belt
if you have tried everything ,take the car to an accredited auto electrician and have it all tested
Sep 13, 2015 | Chrysler Cars & Trucks
86 buick skylark overheating
Sounds to me like you addressed everything but the radiator. Check it or just replace it.
Sep 05, 2014 | 1986 Buick Skylark
I dont like how my 89 fox body mustang shifts I wanna know how to change it from automatic to manual???? About how much? How much work is it? Any info?? Plz
I don't know cost but you're looking at a HUGE amount of labour.
We did this converting an auto-equipped Mustang for road racing. You'll need a donor car as you need to swap the pedal assemblies, steering column, console, transmission, bell housing, and transmission cross-member. The auto trans coolant lines in the bottom of the radiator can be cut & crimped shut. You will need to cut a hole in the transmission tunnel for the stickshift to fit through - handy having the donor car available so you can cut the right size & shape hole in the right place. Because we used a HD transmission for racing, we had to hammer the transmission tunnel in a couple of areas to provide adequate clearance. I don't think you'll need to swap the instrument cluster unless yours shows the auto trans gear position.
Mar 01, 2011 | Ford Mustang Cars & Trucks
Radiator fan motors not working-engine overheating. I checked the fuses(under hood) and took out the square relays(no way to test that I know of) everything looks and test ok
Try replaceing the tempuratiure switch.The relays can be tested by putting power to pin 85 and ground to pin 86 and then check to see if there is good continuity between pin 30 and pin 87,you need an ohm meter for this.
Oct 31, 2009 | 2000 Pontiac Montana
Tranny goes in reverse but wont go into foward gears
how many miles on trans? does fluid smell burnt?350 turbos are good tranneys but they do go bad. in my experance its reverse that goes out first on thies transmissions but thats not saying that it does not happen the other way either. my best guess is you need a rebuild. when you say it tries to move in forward gear that tells me that the clutches are shot. 350 turbos are worth rebuilding. its up to you.
Jan 07, 2009 | 1991 Nissan Sentra 2 Door
1991 and 1997 VW Jetta Radiator??
massive size difference get the proper one or you will be overheating next
Jan 02, 2009 | 1997 Volkswagen Jetta
Chassi swap
yes everything is interchangeable except maybe the driveshafts. you will have to bolt everything up the measure the distances
Nov 30, 2008 | 1984 Ford F 150
1990 fuel injection engine into an 86 Z28
you can get an "engin swap wiring harness" from jegs or summitt that would require a little extra work on the wiring on the inside of the vehicle, however if you have the original wiring harness for the 90 engine, there is a plug on the inside of the right(pass) fender of the camaro that connects the internal wiring to the external. (plus the fuse block connector under the hood on the firewall on the driver's side) as far as the trans. i did the same thing with mine and kept the 5 sp, the only real problem is that i don't have back up lights.
Nov 22, 2008 | 1992 Chevrolet Camaro
JEEP Wrangler Unlimited Toy Vehicle Logo
73 people viewed this question
Top Jeep Toys Experts
Glenn Smart
Glenn Smart
 Brian Main
Brian Main
Are you a Jeep Toy Expert? Answer questions, earn points and help others
