Question about Sanyo DS24425 24" TV
I cannot change the aspect ratio on the TV. When I go to the menu, Aspect Ratio is in red and I cannot select it. On certain channels the screen is too big and I can't see the edges of the broadcatsed image.
This is a quote of what Sanyo told me: "The aspect ratio can only be changed when the unit is in the video mode." So I tried switching modes with the input button and it worked but went to like a letter box/wide screen type of picture, which doesn't help me. We have dishnetwork and on the Panasonic plasma we can adjust the ratio with their remote so I have two options there but not with my Sanyo unfortunately. Hope this helps
Posted on Nov 09, 2009
DOES NOT FILL SCREEN HORIZONTALLY
You can change how your tv displays in the video setting menu under display. You will have a choice between 4:3, 16:9, 16:10, cinema or automatic. I think to fill your screen the best you should choose 16:10 but this is not going to guarantee that all channels will fill the screen. It still has to do with how it is being broadcast to you.
Jan 25, 2016 | Televison & Video
Daewoo DTQ-19TV1fc aspect ratio changed to letterbox. How do I restore it to full screen?
get the on screen menu on the screen
scroll around till you see aspect ratio and click on that use the buttons to change ( you will see the changes on the screen)
click ok and exit when satisfied
Fir aspect ration to change there can be a few reasons
some tv stations produce movies in the wrong ratio and it shows up for the movie as black edges or tall figures or fat figures ( change channel to verify)
or there can be a fault occurring in the board of the set that will not hold preset aspect ratios
Oct 26, 2015 | Daewoo Televison & Video
How can I get rid of the nasty wide horizontal line on the screen of our TV manufactured 2008...? Will It be expensive to repair...?
If by "nasty wide horizontal lines" you mean LETTERBOX masks (at the top and bottom of the screen), all you need to do is select the correct ASPECT RATIO for the program you are watching. Consult your USER MANUAL to determine the menu settings for ASPECT RATIO.
If you do not understand what "aspect ratio" means, or what different aspect ratios exist, do an Internet search for "aspect ratio" and read.
May 21, 2015 | Televison & Video
I have a 55cm TFT LLED-22FHD TV. The aspect ratio is 16:9. This is too wide and the images appear fat. How do I correct this.
Go to the picture menu and select a different aspect ratio. Auto sizing is useful as the TV will detect the picture size and select the correct aspect ratio, except for letterbox and super wide screen of course as your screen is not the right shape for those.
Hope this helps.
Nov 17, 2010 | Televison & Video
Signs that the bulb in a dlp is going out
A DLP Lamp will fail in two ways. 1.The glass tube housing the filament will shatter and the TV will not turn on. 2. The lamp has many hours of use on it and will gradually grow dimmer. At no time will the lamp cause any picture defect. Check your Cable or Sat box for the correct aspect ratio as well as the TV aspect ratio. Chances are the aspect ratio in either system is set incorrectly. If the gray borders are uniform then the aspect ratio is not set properly. If this occurs on certain channels but not others then the particular channel is broadcasting in the 4:3 aspect ratio and there is nothing wrong with your set.
Apr 12, 2010 | Samsung HL-67A510 67" DLP HDTV
Picture size doesn't fit the screen I tried to adjust the aspect ratio but the option is locked on the menu. What to do? (Olevia TV model lt42hvi
You cannot change aspect ratio when recieving HD signal. Try changing the cable box or satellite box format or aspect ratio.
Dec 30, 2009 | Televison & Video
How do I change the aspect ratio
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
Aug 16, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Occasionaly a wide screen dvd plays only in full screen
The aspect ratio on your DVD player is not set correctly. Look for a SETUP button on the remote control, there should be something like "QUICK SETUP" or something similar on the setup menu, if not then go to the menu that has the aspect ratio settings listed. Change your aspect ratio to 16:9 WIDESCREEN, and this should solve your problem. Your aspect ratio is 4:3 which is for a regular TV, if the images (especially people) look real skinny and tall on your TV then your aspect ratio is not properly set. Good luck to you!
Jul 30, 2009 | Oppo Digital DV-981HD DVD Player
Onkyo TX-SR606 aspect ratio issue
you may want to try changing the aspect ratio on the HD box and the DVD as opposed to the receiver. This should do the thing
Mar 04, 2009 | Onkyo TX-SR606 Receiver
Aspect ratio
You may have a vertical circuit problem causing the picture to stretch out. This is called "over scan". You need to have a tech check it for you. Stargazer
Apr 19, 2007 | Sanyo DS24425 24" TV
Sanyo DS24425 24" TV Logo
1,301 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
