Question about Toshiba Satellite P105-S6197 Laptop Notebook
My laptop LCD screen started to have vertical lines all the way across the screen. It was like every other lines was gone so there was a picture, it was just degreaded. That lasted off and on a few days then stopped. The last night the screen went blank with only a light along the bottom of the screen, a back light I guess. I can adjust the screen brightness on the keyboard and I can see the light along the bottom edge brighten and dim but no picture.
  • 1,183 Answers
The problem is more or less with the LCD panel . The problem is generally caused by a faulty LCD inverter cable.
To check weather its the LCD or the video card causing the problem. Connect an external display to the laptop Tap on the Fn + F8 key to toggle the display to the external display. if you see video the LCD would need to replaced
Thanks for using Fixya
proton
Posted on Jul 22, 2009
    Sergeant:
  • 400 Answers
On Board video card is dying
My Sony Bravia KDL-46W-5100 has developed vertical lines. Any advice would be most appreciated.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 07, 2016 | Sony Televison & Video
Getting a vertical green line across my laptop screen
SOUNDS LIKE YOUR SCREEN IS CRACKED OR THE LED INSIDE THE SCREEN
Jul 14, 2012 | Computers & Internet
I have 5 thin vertical white lines on the screen sound is fine.
It looks like the problem is comming from your LCD chips, they are starting to burn out and that is why you get this lines across your tv set, if you leave it like that the problem is only going to get worst
the lines will get bigger until it finally covers your whole screen you need to replace the OPTICAL BLOCK to fix this problem
good luck hopes this helps
please rate this solution !!!!!!!!!!!!!
Jul 05, 2010 | Hitachi FDX Series 43FDX10B 43" Rear...
Picture blank
Maybe it needs to be replaced with something more up-to-date.
Jun 26, 2017 | Sharp LC32D62U 32 in. LCD HDTV
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Colorful vertical lines on screen
more likely to be bad LCD panel (very expensive), but you can try replacing the LCD controller first (around $80~100).
Dec 01, 2009 | Samsung LNT4066F 40 in. LCD Television
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
I have a HP ZD8000 Laptop.I get square patterns across my screen and sometimes just vertical lines. the problem sometimes goes away but also gets worse when I put pressure on the LED panel.
If you are getting the same screen in BIOS then the LCD screen has gone bad and needs to be replaced but if not then do a BIOS update and then reinstall the video driver and restart the Laptop.
Oct 07, 2009 | HP Pavilion zd8000 Notebook
Laptop screen displays vertical lines of various colours
Have you tried to connect your laptop to external monitor?
If you get normal picture on external monitor, then you need to replace LCD screen, but if you get same picture on external screen, then unfortunately you will need new motherboard, because graphics card is integrated to motherboard.
Aug 13, 2009 | IBM ThinkPad R52 Notebook
Vertical lines on my laptop screen
white vertical line on my screen of my laptop..how can i fix t
Oct 26, 2007 | Compaq Presario M2000 Notebook
Toshiba Satellite P105-S6197 Laptop Notebook Logo
218 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
