Question about Kitchen Appliances - Others
Will the alarm go off or not?
If the chime does not go off when I open a door, when I open the same door while the alarm is on will the alarm go off?
    Scholar:
  • 113 Answers
Hi, alarms can be programmed to chime/not chime etc. Simple way is actually test it just to be sure. Set the alarm and try the door. If it doesnt work, then the door sensor could be faulty OR that chanel could have been programmed to be bypassed. Will require the user man for programming. Best of luck
Posted on Jul 22, 2009
15 year old micromark intruder alarm need to switch off
Not really enough info to give you an answer, but I can generalise...
You say Knocked alarm box with ladder alarm started"
If the fault is there permanently from when this happened there's a good chance that you have disturbed the tamper spring/switch on the cover of the alarm unit. when the front of the panel is removed you should be able to see the Sping/switch which is automatically depressed by this front panel, you may find the spring has fallen off the switch or gone out of alignment, refitting / realigning it should remove the tamper fault once the lid has been refitted properly. As for "bleeps when doors, windows opened"
This sounds like the "Chime" feature has been switched on and without the manual I cannot tell you for sure how to switch it off.
Chime is a feature which "Chimes" when a door is opened (Not often used on windows), if this started when the ladder fell on the panel it is most likely just a single key press to switch it off, Once the tamper fault is sorted you should be easily able to find the correct key press to turn the chime feature off.
Sorry for being a bit general but I don't have that particular manual. Hope the info helps you :o)
Mar 20, 2017 | Home Security
How do you disable the door chime?
many drivers have dash lights to inform them that a door is open yet they still drive around and then complain about a knock some where in the back
I would check all the door sensors for adjustment and leave the alarm alone as , as annoying as it might be , it might let you know when a child has opened a door without your knowledge and save a life.
Mar 25, 2015 | 2009 Toyota Camry XLE V6
Door chime alarm
there is a knob on the door fram that triggers the chime..
tape it down with duct tape
fixed
Nov 22, 2013 | Kitchen Appliances - Others
We have an NX-148E keypad. Our building has 4 doors alarmed to the panel and the Chime sounds when any of the doors is opened. Is it possible to set the Chime only to sound when 1 of the doors is op
I am sure there is separate programming for each zone. You will need the manual for the system. Probably can get it on line. This chime feature usually comes from the factory with no zones programmed for reporting. Hope this helps
Oct 03, 2012 | GE / Caddx Networx Programmable LCD Keypad...
Location of tail gate alarm on 2004 Chrysler Pacifica
you may have a bad switch which is located on the latch asm
Sep 03, 2012 | 2004 Chrysler Pacifica
Radio on but no sound and door chime not working
door chime is activatid by switch on door raido should only come on when key is in on or acc setting if key is not in all the way door chime should not come on at all
Aug 25, 2012 | 2003 GMC Sierra 1500
My door chime wont stop ringing when the driver side door is open and the keys are out of the ignition. how can i fix this?
I just found out that the problem on our 1998 windstar was the chime switch attached to the ignition switch. This chime switch when dislodged will short and act as if the keys are still on when the door is open ( thus sounding off the alarm). I had a hunch that the problem was close to the steering wheel because the alarm would stop if I change the angle of the steering wheel a couple of notches up or down. I guess when i did that the chime switch that i'm pertaining to get reset to the right position and stops the alarm. when i opened up the steering wheel housing around the ignition , the chime switch fell, it had a blk wire I think, and I saw that the clips on it were kind of melted thus not sticking to its right position. I just had to remove the ignition switch for a while and replaced the chime switch with the help of a zip tie wrapped around it. then I placed every part back together and no chimes... also I did this all while the battery was disconnected because i needed the ignition switch to be in the on position to get it off the steering wheel. Good luck guys!
Apr 30, 2010 | 1992 Honda Civic
Door chime wont stop
thgis problem is caused by one or more defective door ajar/courtesy light switches or sliding door contacts, since these switches are very hard to replace as they are located inside the doors on the door latch the best thing to do is have the dealer hook up a body module scanner, it can ID the faulty switch, then i f wish u can change it to save money, the switches are about $15 each, there are 5 of them
Dec 21, 2009 | 1998 Ford Windstar
1997 venture keyless remote programming
SYSTEM OPERATION
System warning lamp located on top of the instrument panel
Press UNLOCK button once , turns on interior lamps and deactivates alarm (if fitted)
Press UNLOCK button twice w/in 5 seconds unlocks all doors, turns on interior lamp and deactivates alarm (if fitted)
To activate alarm system (if fitted):
Switch ignition OFF
Open driver's door
Press Lock button on remote
Close Driver door
warning lamp will flash when system is activated
Press remote power sliding door button will open sliding door (if fitted) only if unlocked first
Pressing remote panic button:
*Sounds horn intermittently
*Flashes exterior lamps
*Turns on interior lamps
**Pressing panic for the second time OR switching ignition ON deactivates alarm.
PROGRAMMING
Remobe key from ignition switch
Remove the "BCM PRGRM" fuse, from the fuse box
Close all doors
Turn ignition switch to the ACC position
With in 1 SECOND , turn the ignition switch to OFF then back to 'ACC'
(really, with in one second)
Open and close the driver's door. A chime will sound, indicating programming mode activated
Press and HOLD LOCK and UNLOCK SIMULTANEOUSLY untill a chime sounds 2 times ( about 15 seconds)
Repeat this exact procedure for all remotes to be programmed
Remove key from ignition
Refit 'BCM PRGRM' fuse.
4 REMOTES MAXIMUM CAN BE PROGRAMMED
Aug 24, 2008 | 2000 Chevrolet Venture
Kitchen Appliances - Others Logo
97 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
