Question about Brother MFC 420CN All-In-One InkJet Printer
Scan unable AF
The light bar starts and returns on start up then trys to go across and sounds jammed and knocking
  • lpk8 Jul 22, 2009
    still same thing moves a little to the right then back to the left and it does not seem to finish the back swing Lee
  • lpk8 Jul 22, 2009
    also now that I opened it and have tryed to close it there is no lighting or text info in the screen it has gone blank
  • 42 Answers
Theres a wirestrip that moves it and if you check that it might start working or your rollers are jammed
Posted on Jul 22, 2009
I solved it. I have a "Johnny come lately" 7 years after the question was asked. There is a cord that I could see, almost paper thin and wide through the scan window. I followed the cord down and had to partially open the side of the printer just enough to fuss with it. I unplugged the cord, straightened out one little bent pin, plugged it back in and viola. It works. Other's problem may be different, but it's worth a try.
Posted on Aug 12, 2016
Hyundai Atos Gls 1999. Will not start , no sound at all!
check your battery for a dead cell, make sure it is not over 5 years old. If that doesn't work, try tapping on head of starter while someone trys to start it at the sane time
Apr 29, 2016 | Hyundai Cars & Trucks
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Mar 31, 2014 | Brother MFC Office Equipment & Supplies
Ignis 1.5 sport 04
post all signs of overheating.
  1. dash guage
  2. STEAM eruptions>?
  3. AF (antifreeze ) leaks?
  4. CHeck engine light sticks on running?
  5. Scan tool shows way hotter than 200F? "ECT PID" parameter.
  6. oil in the AF? cold you see oil floating in the neck of the rad cap off?
  7. AF found on the A/T tranny dip stick end?
  8. Loosing coolant (drops) all the time, Check rad directly cold.?
  9. engine pings, (knock/detonation) ?
  10. lost power. from engine.
  11. shaking of engine. as it misfires.
  12. car heater makes this odd gurgling sound?
those are the signs but. what about precondtions.
overheats only parked< and never moving fast>
yes, bad RAD fan, (or its controls)
over heats all the time>?
fan belt fell off or slips?
clogged, rad tubes. (inside)?
water pump bad, blades, rusted to nothing.?
thermostat died, as most do way before 10 years,,,,,,,
clogged system from not doing the 2year service.
Mar 15, 2014 | Suzuki Cars & Trucks
I have a Brother MFC 8440. The scan bar has stopped functioning the bar deos not move to scan the documents. It makes intermittant sounds but seems stuck in its resting place?
If the device was moved without the light bar being locked prior to moving, it is possible that the light bar was knocked out of alignment and it will not work. It is very important to lock the light bar prior to moving for that very reason. I would suggest you take the device to a qualified specialist to identify the issue.
Nov 04, 2011 | Office Equipment & Supplies
Scanner bar will not reset, error "unable to Init. AF"
the problem might be the connection from the mother board of the printer to the scanner maybe due to lost contact and the ribbon was broken you might just have to reconnect it or it might be broken and need replacement
May 10, 2009 | Office Equipment & Supplies
Sharo al 1631 makes clicing noise and does not
Sounds like your scanner is jammed or the scanner motor has failed.
If you are so inclined, turn the power off, you can remove the glass and try to move the scanner by hand, if you can't move it then it is jammed, if you can move it to the middle and turn the machine back on, does it return it to its home position? if so, the motor may be OK, but the control board may have a problem, if not, the motor have likely failed.
Hope this is of some help.
Ed
Apr 30, 2009 | Sharp AL-1655CS Copier
Starting
The fastest solution now would be to take a hammer and gently knock the starter (it's the part that makes the click when you turn the key). If you can't reach it with the hammer, use some bar or metal pipe, put one end of the pipe on the starter and knock the other end.
This solution may do the trick if the relay is jammed, and usually helps you to go to the nearest mechanic who should change the bad part.
Sep 16, 2008 | 1991 Ford Ranger Supercab
Brother printer HL2040
Try changing the toner cartridge.
If you are useing refill cartridges and the roller starts to cease
up, the printer still trys to drive it and causes all sorts of problems.The worst thing that can happen is that the drive
gear inside the printer shatters and you will be unable to remove
the drum & toner consumables.
mongrelken.
Apr 13, 2008 | Brother HL-2040 Laser Printer
Init unable AF
AF means that the CIS scanner is (can) not (get)in right position. This could be because of a broken scanner flat cable, or a loose flatcable or a defective pcb. Check flatcable connection at the pcb (Open scanner like changing carts, open flatcable cover with a screwdriver. Does the flatcable stick in the pcb? (There is only the flatcable without a connector ;-)) Reconnect and power up mfc again. If it doesn't help please write again here.
Sep 13, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
1,006 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
