Question about Hanns.G Corporation HW173D Monitor
Green light flashingbut moniter is not showing anything
  • TroubleShooter May 11, 2010
    flashes just once, or continuously?
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. Look in our monitor repair section for step by step repair guide for this model. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 22, 2009
My moniter is showing no signal with 3 colored stripes g on green r on red b on blue. I have a wireless logitech mouse and keyboard and the reciever is not showing the 2 green lights meaning its on. Do I...
ok your monitor is a separate issue and start by checking the blue signal lead from the back of the monitor because for some reason the monitor isn't getting any images to show
Feb 02, 2012 | Gateway Computers & Internet
Daewoo Moniter blank screen
First make sure that all the cords are connected properly from the back of the CPU to your Monitor.I suggest you to unplug all the cords of the CPU and then plug them back in after 10min. and make sure they are all connected tightly.Next check if the power cord connected to the Monitor is attached tightly.
If you still face the problem then you will have to replace it with a new power cord whih connects the CPU to your Monitor.It is black in colour.
Sep 30, 2008 | Gateway FPD2275W LCD Monitor
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
My power light is on but the monitor is black. Is
your moniter is not broken your moniter's data cable is not correctly pluged.
Jul 30, 2009 | Dell E173FP 17" LCD Monitor
Monitor is blank when comp is on
if the moniter light is keep lighting than there will be problem with your video card check the cable connections of your moniter . if ot not work than change your video card.thanks and take care
Apr 27, 2009 | Computers & Internet
Moniter doesnt show anything
ok check you video driver because if your moniter is working with other computers then that could be what it is but let me know if anything else happens
Nov 07, 2008 | Soyo SY-K7VME Motherboard
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
15.6 lcd wide moniter (low light)
It's LCD pannel problem
Remove the LCD pannel and checket flowrocent tubes at top of LCD Screen and Bottom of LCD Pannel. If U Find any burning area at end of F tube, please clean it and solder the flowercent tubes in same possion and connect as same.
Oct 03, 2008 | Acer AL2216WBD LCD Monitor
Screen color problem
Some circutes are not working properley so please go to your nearest service center otherwise call to the moniter service center
Jun 23, 2008 | Computers & Internet
Green led light flashing on 700p proview flat panel and no picture
Any high switching power supply of the same voltage and amperage rating will work for you. You may have to cut the end off of your old one and wire it to the new one to make it work but don't waste your money buying a specific power supply.
Good Luck!
Feb 16, 2008 | Computers & Internet
Hanns.G Corporation HW173D Monitor Logo
443 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
