Question about Recoton Advent Advent HT3251A TV
Advent Tv on direct tv with snow showing on screen
Our Advent TV model HT2751A was working until I hit something on one of the remotes (either the one for the direct TV, or the remote that came with the set) It was showing a blue screen, now it is just snow. I called the direct tv support we did every thing they could think of & still nothing but snow. The direct tv box works, we tried it on another tv. Is there anything we can do to fix this tv? The customer support phone line has been disconnected. Thanks for any help!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
I can only get channels 600 through 900 which I have never see before.I cannot get regular channels or cable channels.It is not a flat panel t.v.Q1435A is the model number
Hi -
If you have a cable TV line connected directly to the TV, an antenna or a cable box connected by coaxial cable, I would suggest running the automatic channel scan (AUTO-PROGRAM) again:
1. Press the AV key on the Advent remote control repeatedly until TV is displayed in one corner of the TV screen. If you don't have the Advent remote, use the TV/AV button on the front of the TV.
2. Press the MENU key on the advent remote or the front of the TV to open the on-screen menus.
3. Use the CH+/- keys on the remote or on the front of the TV to highlight PRESET then press VOL+ to select.
4. Use the CH+/- keys on the remote or on the front of the TV to highlight ANTENNA then use the VOL+ key to select either AIR (for antenna) or CABLE.
5. Use the CH+/- keys on the remote or on the front of the TV to highlight AUTO-PROGRAM then press the VOL+ key to start the automatic channel scan.
Once the channel scan is complete, the TV should automatically return to viewing the first channel found during the scan. Do not press the MENU key during the scan or the scan will not complete.
If you are using a cable/satellite receiver and it is connected to the TV by any means other than a coaxial cable, you do not need to run the channel scan. You should simply select the correct AV input using the AV key on the remote or the TV/AV key on the front of the TV (see step 1 above).
If you have done all of the above and you are still unable to get the channels on your TV, please post back for further assistance. You can reply to me by clicking on "Add a Comment" below your question. Please let me know whether you are using a direct cable line, antenna or cable box, etc.
Regards,
BElectric
Mar 26, 2011 | Televison & Video
Model ht2751a no power,clicks and power light cuts on and off
I replaced caps in power supply.set work fine now.when off light stay blue,when on light is anber.
Jun 18, 2009 | Recoton Advent Advent HT3251A TV
How to unlock the parental control on Advent Q1435A
I'm having the exact same problem with the same TV right now, would love to know how you fixed it as I've lost the user guide. Thanks
Dec 02, 2008 | Televison & Video
Press and hold the display for some time (say 20sec) and this should solve the problem. It solved the problem for me
Oct 30, 2008 | Recoton Advent Advent Q1435A TV
I need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
Jul 24, 2008 | One For All URC-3021 Remote Control
Looking for schematics for a Advent TV HT2751A HDTV?
try this
http://www.servicemanuals.net/
Jan 04, 2008 | Televison & Video
Advent 27 inch flat screen
i have model dv2020a television and it is locked. i cant unlock my television. i don't have the remote i have a universal remote can u help me.
Dec 20, 2007 | Recoton Advent Advent DV1418A 14 in....
Advent HT2751A display no good until after 1-2 hour warmup - maybe
After 3 years, I finally decided to open up the TV and do some troubleshooting. Found out the problem, It was a blown capacitor Location C554 Capacitor value is 2200uF 16V - costs about a dollar to replace yourself and the TV works brand new.
Aug 16, 2007 | Recoton Advent Advent HT3251A TV
Televison & Video Logo
155 people viewed this question
Top Recoton Advent Televison & Video Experts
Jaime Hernandez
oodio
oodio
Level 1 Expert
Jason Morris
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
