Televison & Video Logo
Posted on Nov 20, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with picture
I have daewoo model CTS 2090. The color picture is great except there is
a black rectangle (approx 12'' x 5') covering part of the lower half of the picture. This happens even when I am watching a DVD, so I figure it's the TV.
  • puttone Nov 10, 2008
    I don't know how to shut off the closed caption
Anonymous
Level 3:
  • Master 934 Answers
  • Posted on Nov 20, 2007
Anonymous
Master
Level 3:
Answers
934
Questions
Helped
504616
Points
2229
Go into your menu system and turn off the closed caption.
Bill
  • Jeff Leyva Aug 31, 2013
    Yes, it also happen on one of tv, which is a PROMAC model 2090. The same problem and the same solution which was happened a long time ago.
A
Anonymous
I have lost my remote to the tv and are unable to access the closed caption from the menu. is there a way i can do this
i cannot get it off the bottom of the screen
email [email protected]
or [email protected]
Black vertical line down Sony TV screen
that isa capacitor at vertical area mostiy 1000 uf to 22000 /35volts
Our 13" tv has deveoped
Hello jcdcam,
Welcome, and thank you for using FixYa!
Your issue is caused but the logic control to the menus displays being "Stuck".
You can try this simple fix before following up with my next suggestion; if the first doesn't work.
Unplug power to this TV and pull the batteries from your remote for 15 minutes. Afterwards, put the batteries back in and plug the TV back in. If the picture is normal, "Yea! We win."
If the picture returns with the "Dark Menu" you will have to have the tuner control board replaced.
Have a great day!
The "cardboard" type plate over
is a wave cover,can be replace
I get a large black rectangle covering 1/3 of my
I have a similar problem using an older 20" flat screen standard definition TV. (not High Def). I can see a little of the picture but more than 2/3 is covered by the black. My model is LC-20SH7U.
I used sharpusa.com "contact us" section.
Hopefully I get some kind of reply to report what they say.
5helpful
2answers
Daewoo DTQ-27U4SC Display Problem
Sounds like your closed caption may be on and here is how to turn it off..
1. Press the menu button until you get to the "SPECIAL" menu.
2. Make sure that Closed Caption and CC on mute are both set to OFF.
This should make that black box go away...
Good Luck and please rate this solution...
Black vertical line about 3 inches wide from top to bottom on rig
See if you can center the picture in the setup menu. It sounds like it's just off center.
1helpful
4answers
Daewoo CTS 2090
try this ENTER MUTE PR UP PR DN ENTRE OR TV IN STAND BY MODE only do as AV SLEEP CLEAR POWER buttons on user remote with in 10 seconds. or go to web site remotes.com
NO Picture in Color except for PIP
have a tech check your tv the color circuit needs to be looked upon.good luck
No picture on 42" plasma TV.
take your tv to a tech the tv is having problem in the color circuit and the vertical circuit.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
