Question about Sony PlayStation Portable (PSP) Console
Power won't turn on psp - Sony PlayStation Portable (PSP) Console
My system wont charge
Posted on Jul 28, 2009
    Problem Solver:
  • 13 Answers
Battery might be burnt, try using the charger if it works buy a new battery, if not system is dead
Posted on Jul 24, 2009
I dropped my psp and it broke and won't turn on. I
Something more than likely chipped off/broke from the impact of the drop. Have you tried opening the PSP? *Note - opening your PSP will void your warranty.
Apr 04, 2012 | Sony Video Game Consoles & Games
I have just received the psp-1001 from a friend, the battery is fully charged but it won't turn on, is it a lost cause?
Better bring it first to some PSP tech to verify the problem of the board, some micro fuses might have blown.
It takes some soldering to replace it
Hope that helps you!
Oct 02, 2011 | Sony PlayStation Portable (PSP) Console
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
Psp won't turn on. got new battery.
Did you try to use the charger and turn on the PSP? If you use the charger and the psp turned on, the problem would still be the battery, you bought a defective one and have it returned where you bought it. If it did not turned on using the charger, the problem would be internal, a micro fuse might have blown up and needs to be replace. An experience technician in PSP could replace it, because it needs to use soldering.
Hope that helps you out!
Jul 03, 2011 | Sony PlayStation Portable (PSP) Console
Psp green light on, but no booting or anything. its not a fault of Software... its Hardware for Sure! any help?
Hello
If the green light comes on, but the unit won't power up, you could have a battery problem.
Clean out the battery compartment. Use a can of compressed air to remove dust, hair and other debris. If you left the battery in while you stored the unit, look around the connectors for any sign of corrosion that could be affecting the connection.
Plug the PSP into the power adapter with the battery still inside. If this doesn't work, remove the battery and see if the PSP powers on with the adapter only. If it does, then the battery likely needs to be replaced.
Boot the unit in recovery mode. The PlayStation Portable is like a small computer with a tiny hard drive. And just like a computer, sometimes it gets scrambled; booting in recovery mode can help you identify or correct the problem.
Determine if your PSP has been "bricked." If the PSP was turned off for any reason during a firmware update, it can cause "bricking," so named because it renders your PSP into a useless, plastic brick. Buying a new PSP or sending yours to Sony for repair are your only options if this has occurred.
Jun 10, 2011 | Video Game Consoles & Games
Psp power up green lights on black screen after a few seconds shuts down psp slim
it sounds like you bricked you psp, if it's not a 3000 or psp go you can probably fix it by buying a pandora battery and magic memory stick.  you can buy them from here http://pandorasales.com/?gclid=CNLk1fzUzqgCFcO8KgodAzI2lA , if you are running a psp 3000 and up, you could try to format your memory stick but it probably won't work.
Apr 25, 2011 | Sony PlayStation Portable (PSP) Console
PSP Won' turn on
wait, so when you turn it on, the wave shows or nothing shows? and to turn it back off you have to hold it for like 30 seconds.
Sep 23, 2009 | Sony PlayStation Portable (PSP) Slim...
My psp dosn`t turne on any more.any help?
do you install custom firmware? coz if you do maybe it got brick. try using pandora battery if it works. if it still dosen't works you may have a hardware problem.
Jul 19, 2009 | Sony Video Game Consoles & Games
My psp scrreen won`t work
ur psp lcd is broken...go to the nearest psp service repair and they will fix it...
May 10, 2009 | Sony PSP (Piano Black)
My psp wont charg
If it won't charge and wont power up then same thing happened to me. If you are willing to open up your psp there is a video on youtube that can show you whats wrong. The cable that connects the buttons on the right side most likely disconnected from the main board and the right side of the psp including the buttons, the power switch and the top right trigger won't respond. When you try to turn on the psp and when its charging if the light won't come on then you might have this problem.
May 10, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
152 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
