Question about LG WM0742HWA Front Load Washer
Barrel won't spin
Solution for "I have an LG 7kg front loader machine, barrel wont spin easily It seems to stick in one area". When empty and turn the barrel manually it squeaks in one spot.
danowilliams
  • 105 Answers
SOURCE: Lg front loader makes squeaking sound and
The drum is powered by a small motor and pulley, inside the unit and under the drum. A large belt wraps around the drum and pulley, and a spring "thing" provides tension so that the belt won't slip. The squeaking sound indicates that something is slipping, and the sluggish drum says that it's the drive belt. Take off the back, locate the motor/pulley/spring thing, and check the belt tension by observing the belt with unit operating. At that point you should easily locate the noise, at the motor (noisy bearing, lube or replace), belt warn (replace) or possibly the felt pads located at the top of the drum worn (not as likely but they do fail causing the drum to resist being spun by the motor to the point that the belt starts to slip. Hope this helps!
Posted on Jan 08, 2010
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
TheMobilian
  • 8220 Answers
SOURCE: How do you change the front door seal on a LG 7kg
Well I have the manual. If you want it.If the problem is water leaking out the door LG recommends you shim the door latch with washers. This would make the door close tighter and eliminate leaks. See page 36
Posted on Mar 12, 2010
SOURCE: LG WD-8050FH LOUD noice when spinning & 'funny' burning smell!!
I had the same symptoms and almost dismantled the whole machine to locate the root of the cause. The issue was one of the 3 arms of the spider (like a 3 spoked wheel that connects to the rear of the drum and holds it in place and provides the drive shaft to through to the motor at the rear), had snapped after weakening from corrosion due to undissolved washing powder building up in the grooves.
To prevent this, do a hot wash every few weeks to dissolve the powder, don't think your saving the environment by using only cold washes, this should be in every washing machine manual to save the environment from waste from un-economically repairable appliances.
The burning smell was the unbalanced drum leaning heavily on the rubber shroud on the front between the drum and the outer casing. The replacement spider part was only about AU$60-80.
To check if this is the problem you may be able to tell by opening the door, and reaching in from the front with your palm up about a hand distance till you go past the rubber shroud and just touch the stainless steel drum. Grip it gently with your four fingers and pull towards the front (to you) about 1cm or two, with about as much force you would need to open the machine's door. Rotate the drum approx one third of a rotation and repeat, do this 3 times and you should feel one point give more than the others.
If no luck try again in sixths of a rotation, you can gauge the distance by the 3 plastic agitators attached on the inside wall of the drum.
Note: get a price on labour first to replace the spider, as this will be probably more than half way to a new machine, and then the cost of the part, and the call-out fee if you can't get it into a service centre.
What's the point of having a long lasting stainless steel drum when the key part that connects the drum to the motor is a weak cast iron / alloy part.
Ask your local service person what units have quality parts before buying a new machine.
ps: the loud noise is probably the cracked arm rubbing or the unbalanced drum hitting the sides and making the machine jump.
Hope this all helps!
Posted on Apr 06, 2010
sonicboomele
  • 1557 Answers
SOURCE: i have a lg intellowasher 7kg wd-8015c (front
the water pump is sending a signal to the pcb telling it there is a fault clean the filters and wheel on the water pump
let me know how you went
sonic boom electronics
Posted on Dec 28, 2010
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
I have a lg intellowasher 7kg wd-8015c (front loader), and its not spinning and the clothes come out wet. whats wrong and what parts will i need please
If the washer is not spinning you need to check on the motor, motor capacitor and the power from the program controller unit. If there is no power to the motor then the controller is a suspect.
Please check this link for tips: removing the motor:
Jun 23, 2012 | Washing Machines
How do you change the front door seal on a LG 7kg front loader washing machine
Mar 12, 2010 | LG Washing Machines
Something is stuck in our LG front loader washing machine so the water wont empty in the spin cycle
There should be two screws under the front lower panel. Remove the two screws and remove the lower panel. You should be able to access the pump from here.
Inscrew the cover on the front of the pump and clean.
Dec 31, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
LG front Loader Intellowasher 7kg WD-8015c has been on a quick 30 mins cyle and is still going after 1 hours just keeps spinning and won't turn off
I have the EXACT same problem wit the LG 8015C. After numerous attempts, I finally found the problem. A set of wires attached to the drum body vibrates against th erear panel, wears off the plastic insulation, shorts and blows the circuit board. All because of sloppy workmanship ! It took 4 years of easy work for this to occur. Will NEVER buy an LG or Front Loader again
Sep 18, 2009 | Washing Machines
LG Intellowasher cannot complete spin cycle.
Unplug power cable, remove top cover and inner panel, locate water level sensor on the right with 3 wires and a thin tube, remove the tube and puff into it until you hear water bubbling. This will clear any blockage caused by suds build up. Replace tube, covers and plug back in. It should complete cycles now.
Sep 11, 2008 | Washing Machines
LG INTELLOWASHER DD 7KG
You may need to have the door switch replaced but before that should be done, make sure the wire connector is securely in place.
Sep 02, 2008 | LG WM1814CW Front Load Washer
I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Aug 03, 2008 | Washing Machines
7KG WD-8050FH LG Clean Master Front Loader (5 stars) No Drain ....won't drain or spin
I had same problem and i have opened the the water pump and found some tissues blocked the fan from spining , i remove it and immediatly worked .
Jul 14, 2008 | Washing Machines
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
LG WM0742HWA Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
