SOURCE: Xbox family settings
If you've forgotten the answer to your pass-code reset question as well as your pass code, please call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269). Or you could try resetting xboxs software by ("holding Y while turning on the box")
SOURCE: family settings
You would have to get the old password and stuff from the other people or you can just buy a new harddrive and I think that should work.
SOURCE: Bought it 2nd hand
After conducting extensive research, I have concluded that there is no ID and/or password to reset. According to my research, this is an "unmanaged" switch. It's plug-and-play all the way.
http://www.dlink.com.ph/products/dlhome.asp?sec=&pid=71
SOURCE: my xbox 360 died and i bought a 2nd hand one. I
You have to recover your gamertag for these arcade games to be played again, it's like an anti - piracy feature of the Xbox 360System not to allow data transfer wihtout prior notice. On your new Xbox 360 System:
• press the xbox guide button
• if your are signed in to your profile, you have to sign out first
• after signing out, press the Xbox guide button again and select recover gamertag
• on the next page, confirm on the prompt and follow the onscreen prompt to recover your gamertag
This should allow you to manage and play your downloaded Xbox Live Arcade Games.
SOURCE: my xbox 360 which i bought froma friend says
go to your system settings and change from family to something else
it's under settings, you need to do a factory reset as it were, which will wipe it clean. then you can set it up to your specs.
