Question about Vizio VS42LF 42 in. LCD HDTV
Supposibly power card or mother board went out on a vs42l
Where do I find these item?
    President:
  • Vizio Master
  • 1,779 Answers
You cn try "Shopjimmy.com" and also "Encompassparts.com"
Posted on Jul 22, 2009
Does asus p5n73 am mother board support asus ati radeon HD 6450 graphic card? my smps is 450 watt also let me know which graphic card support my mother board
your power supply is at the edge, so i'd suggest going for 650W power supply. your mainboard will support the graphics card but as i said - you need better PSU
Mar 13, 2012 | ASUS HD 6450 DDR3 PCIE Native HDMI SILENT...
Dell 4400 Main power in house went off while using my computer and then went back on about an hour later. Now when I try and restart the PC, the power button light turns yellow like it is in sleep mode...
The power supply or mother board probably went out. Did any other items in the house stop working? This happened to me years ago and the electric company reimbursed me for damages.
You can try unplugging the power cord for a few minutes, then retry listen for any beeps from the computer. If it is powering on but nothing on the screen and no beeps *********** board is probably toast.
Dec 10, 2010 | Dell Dimension 4400 Power Supply ** FREE...
So i bought a new graphic card, its a sapphire HD 5870 vapor-x 1gb gddr5. after much problems with putting it into the case (the card is very big) i get no picture on the monitor from it, a friend said my...
You can use just about any WATT power supply. The demand of wattage is limited to the use of each item that the computer needs to operate correctly. So you can't blow out your system if you install everything correctly and properly. So you could install a 1Giga Watt with safety. Make sure that the power supply that you get fills the needs of your video card.. Reference the video card box for the proper Power supply..
Thank you for your visit to Fixya.com
Dec 06, 2010 | Foxconn G31MX-K socket LGA775 motherboard
Which Graphics Card is suitable and best for my mother board ASUS P5GZ-MX plz suggest me as early as possible
gaming card
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6705531&CatId=1558
usual use card
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4035118&CatId=1558
Oct 08, 2010 | ASUS P5GZ-MX Motherboard
Bought barebones(B69-9005)hade trouble installing win 7 kept saying no signed driver,. called them , they sent me soft ware for driver install. started dowloading then stoped. now monitor just reads no...
If it has onboard video it may be a bad video cable or messed up pin on one af the connectors. If it is a installed video card the cable could still be one problem but also try pulling the video card out unplugging the power supply cable from the mother board for about 20 seconds or so. Then reslot the video card into the mother board and plug the power supply back into the mother board and see if that helps. I have also had to take the small flat battery out of mother board for a second or two to make it reset. If you decide to do the battery thing make sure the power supply is unplugged from mother board. Good luck.=)
Sep 19, 2010 | Computers & Internet
Power loss after 2 seconds from booting up.
Best solution I can think of is Step by Step
Remove those items again and Step by Step, 1 by 1 install each item.
If each item installs ok one by one, then leave in one item at a time. Slow process yes, but you might find which item is causing the conflict.
If you install smething an the machine fails Remove it and the Item before it, then install the Item that failed and try it again.
If it fails then it could be the item not the PSU.
If it fails because of all the items... Then you may need to upgrade your PSU
May 20, 2010 | Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G...
Screen pink red after installing mother board
uncompatible motherboard with many hardware,
1 - VGA screen card not compatible
2 - if VGA card is on board, then driver in the HD not compatible
3 - Screen resolution set to unsuported screen refresh rate HRTZ
Dec 06, 2009 | Computers & Internet
Comp does not turn on. green light off but goes on when mobo disconnected
Test the power supply in another computer.
If that works, the next thing is to check the mother board. Remove all daughter boards from the slots. Remove all memory, disconnect all hard drives, cdroms, etc.
Make sure there is nothing plugged into the mother board except the video cable (if it is on-board video), if not, then make sure you have a good video card plugged in.
Again with no memory, no boards except a video card, if needed, and the power plugged into the board.
Turn on the power, and watch the screen. If it works, then you should get a notice that there is no memory, no hard drive, and so on.
If that is the case, then proceed to install one item at a time to isolate the problem. If it is not the case, the the mother board is probably bad. One other thing to check would be the CPU.
If you get no notice with the above, then the cpu could be bad. Check it in another computer, if possible. This should tell you what the problems are or is.
In the above cases, either the cpu or the mother board can be isolated to see what is bad, if any.
Oct 07, 2009 | HP Computers & Internet
I have a HP PC. the compouter does not boot. A vendor tested it and said the sound card is gone bad. The sound card is on the motherboard. wat to do?
Unless you love this computer you have to take this mother board to the manufactuer for componant repair.
Could be anything. Diode issue or transister unless you have the schematics for this item you can fix it your self and test, however if you don't love this mother board as you do... might just have to replace the mother board
Sep 07, 2009 | Computers & Internet
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
Vizio VS42LF 42 in. LCD HDTV Logo
105 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
