Question about Toshiba Satellite A60-S1561 Notebook
Toshiba satellite lap shut down. charged and now will not turn on
Laptop shut down, Recharged battery and now will not power up
  • 83 Answers
Try on AC if works replace battery!!swampratt200!!AAAEEE!!!!
Posted on Jul 21, 2009
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite P205d S7479 shuts down suddenly when on battery. The battery is brand new.
Try to turn off the laptop
Remove cables and battery on the pc
Press and hold the power button for 5 seconds
reinsert battery and cables on the laptop
Turn on the laptop
Check if the PC still shuts down. If it is, try to connect the power cable without the battery. If it turns on, call your pc manufacturer to replace the battery....
Jun 21, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba m55-s325 battery charging
I would try another power supply, as the one you have may not be providing enough power to both run and charge the laptop.
Apr 30, 2009 | Computers & Internet
Battery charging problem for toshiba satellite p30-145
After 4 or 5 years, the battery will be too dead or old to take a charge. It needs to be replaced.
Feb 17, 2009 | Toshiba Satellite A105 Notebook
Toshiba satellite x205-s9800 - Frozen boot screen
hi,
try this one
take out the battery and take out the Ac adapter now press and hold the power button for 15 sec this will release any static charge residing in your laptop.
now try start your laptop with battery in.
Further Queries are welcome
Jan 21, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba Satellite 2410-PS241L laptop does not start.
Plug it into the electrical outlet and then turn on your laptop. if it comes on and works fine, then your battery is just simply dead, and if it will charge, just needs to charge. If not, then you are going to have to replace your battery. But assuming all of this is true, and your laptop will power on when using your electrical outlet, then yes, feel free to use it whenver you like when plugged in.
Sep 04, 2008 | Toshiba Satellite 2410-S203 Notebook
My Toshiba Satellie P15-S470 turned off by itself and I can not mak it to run.
Sir:
Is your laptop connected to a power source? If not it needs to be recharged...
Check also the battery of your laptop, it might be dead already... meaning even if it is charging the battery doesn't charge anymore... it may need replacement.
To check the battery... remove it from the laptop and find a flat button to check if the battery is charged, or half charge, or none at all. If below half then the battery needs to be replaced.
Jan 23, 2008 | Toshiba Satellite P15-S470 PC Notebook
Toshiba Satellite A60-S1561 Notebook Logo
121 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
