Question about Dryers
Mayteg model DE313 clothes dryer that stopped drying clothes.
I have a Mayteg clothes dryer, model DE313 series 05, which has sudenly stopped drying our clothes. After setting the AUTO DRY REGULAR CLOTHES switch to the medium - more dry position, and pressing the start button, the tumbler drum turns okay, however the unit never gets hot. That is, no matter how long it tumbles the clothes, upon opening the door, the clothes remain wet and cold. I suspect that the heating element needs to be replaced. Is this an accurate assessment of the problem? Thanks for your help! John Tancredi610-635-0519higbytoys@yahoo.com
  • 55 Answers
That is a very accurate assessment of the problem. Check the element for continuity between its two contacts. If there is none, replace it. If there is, look for a fuse on the side with two wires going to it. Test it for continuity. If there is none, replace it.
Posted on Jul 23, 2009
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
My Magtag dryer model#DG612 (series 05) stopped producing heat to dry the clothes. There was a flame for approx two minutes, and then the fame went out. What can I do to fix this problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 28, 2011 | Dryers
I have a Kenmore 500 series dryer, model number 110.79522800 that will note completely dry clothes. It seems like it doesn't run long enough, heat high enough or a combination of both. What can I do to...
Your Sensor that senses the clothes are wet or dry is shorted out. The dryer works likes this so the dryer heaters dont stay on while the clothes are dry. When the sensor senses the clothes are damp or wet, the heater stays on, when they start drying the sensor senses it and starts to turn down the heaters
http://tlc.howstuffworks.com/home/dryer6.htm
Mar 10, 2011 | Dryers
My Maytag Dryer (Model: DG612 , Series: 05) stopped producing hot air to dry the clothes. I opened the little door on the bottom right hand corner on the front of the machine and noticed that there was no...
Replace the ignitor you broke and check gas valve coils for continuity (they should be in the range of 500 - 2000 Ohm, don't remember exactly). Very likely one of them has failed.
Part numbers for the ignitor (any will do, they're identical):
4391996
WE4X750
5303937186
Part numbers for gas valve coils (complete kit, also identical):
279834
5303931775
Good luck,
Vlad
First Choice Appliance
Jun 02, 2010 | Dryers
Dryer will not turn off
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
Fabric looking belt came out of dryer. when i try to dry clothes it makes a loud noise and smells like something is burning and my clothes get twisted. how do i fix it? I have a kenmore 70 series dryer
Stop using your dryer in its current condition. That fabric looking felt is probably your drum seal. They commonly wear out. I will need your dryer model number in order to confirm how your dryer is configured and give you accurate advice on part numbers and directions on how to replace. The model number should be listed on a name plate around the door opening.
Apr 22, 2009 | Kenmore 63942 Dryer
User manual for Maytag DE313 Series 107
(Click below for user manual)
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=RF262LXSB0&siteCd=WHRCOM
The age of your dryer I'm not sure, The elements for your dryer can be found below, go to my web-page and enter the model DE313 into search feature and you will get pictures of the parts. The element part# is Y313538 (click link below)
http://servicepartstec.blogspot.com/
If you need help, just let me know,Thanks,Sea Breeze
Mar 23, 2009 | Maytag Dryers
Cloths not getting dry
id look into a clogged and or kinked exhaust vent. perhaps where it leaves the home theres a screen over the housing thats clogged itself w/lint. its generating heat, thats good now just needs to release it somehow
Mar 16, 2008 | Washing Machines
Dryers Logo
164 people viewed this question
Top Dryers Experts
