SOURCE: radio does not work
put a wire in the antenna hole while radio is on if you get some reception then you know its your antenna do you have sirius if you do it sometimes it runs through your antenna if you dont then check your antenna wire where it connects to the antenna good luck.....
SOURCE: Converter box installation. Not a clue.
rf cables will work fine for older tvs. newer tvs should use the composite (yellow, red and white cable) to produce a digital picture and sound. FYI the indoor antenna works best when positioned in a window. Best thing to do is install an outdoor antenna in the attic near the gable vent or on the exterior of the house.
