Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
Display has light, no picture
I also dropped my PB G4 in the airport a couple weeks back, and when I got home I turned it on, the display is black and then it turns to white (backlight is on?) when it gets to the desktop. I know this because I had it connected to my HDTV and that's what I saw on the laptop display and the HDTV during the bootup process.
Can anyone tell me if it's the cable(s), inverter board, or the LCD (yikes)? Thanks in advance.
    Scholar:
  • 151 Answers
It may be any one of them, Best bet is if you are on apple protection plan or any other insurance they will fix it for you for free.
Regards
Posted on Jul 23, 2009
I have an old PowerBook g4 in my kitchen for listening to pandora and looking up recipes. All of a sudden, the wifi stopped working. It has dropped out a few times before, but I have always been able to...
Cut the airport off and back on again. After that, delete any wifi profiles you have, and then re-add them. This will clear any corrupt profiles and troubleshoot that. If you can't connect to anything after that, check that the airport card is connected securely. If, after all that, it still isn't working, and other devices are able to connect to the same network, then your airport card is probably no longer working.
Nov 09, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Display won't turn back on
You may need to open it up again and remove first the airport card and turn it back on and if that boot your computer there's a possibility that your airport is causing the problem and the airport may be loose and touching some other parts on it.
Hope that helps...........
Jul 21, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook: I've a PB G4 1.25Ghz, since few weeks, when I'm tr...
Try replacing the inverter board. If that don't help then the next step is the back light, but replacing it is a bi.ch, so most people just replace the whole screen. Also, check that the video cable wire is not crimped/cut and securely fastened onto the logic board.
May 17, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Ibook display went black
There's a couple things you can do that may help. Try opening the display to different positiions. Sometimes the display cable inside gets damaged and you may be able to position the display just right to allow the cable to work. This is a long shot but it's woth a try.
The other thing is to press the fn key and press the display brightness control to see if there's any difference in brightness.
The lcd may be ok, but you may be able to replace the inverter for the display (if you think you can open up and do a bit of disassembly and reassembly). If you want help with this let me know.
The displays, inverters, and cables inside are all replaceable and it's considerably less expensive than purchasing a new one. There's several companies that can do the repairs. One is powerbookmedic (dot com). they also have repair how-to guides and videos... if you feel comfortable with do-it-yourself...
There's plenty of parts available for the G4...it's a great machine.
Jan 02, 2010 | Apple iBook G4 Mac Notebook
Hello, i recently bought an airport card off of ebay and installed it in my G4 tower (mirrored drive doors). the OS has been upgraded to Leopard. I cannot get it to turn on. When I try to configure...
Hi Kathy
What message do you get? does it say anything like "Not airport card found" or something similar.
A couple of things to check. First make sue that the card itself is fully home in the socket. Second, make sure that the arial lead is properly connected. It is really easy to think that the arial is connected when it isn't. The plug is a very close fit. it should click into place and you should not be able to get a finger-nail between the plug body and the card - if you can it's not connected.
Failing that, the card may well be faulty - sometimes happens with eBay.
Oct 28, 2009 | Apple iMac G4 Desktop
Airport connection - G5 Powerbook
Yes better get a new wireless card if there's a airport that can be connected via USB that will be better..
Good luck....
My minolta dimage X20 whern turned on is all ready to take a picture but is only showin blackness, i can preview pictures etc and do every thing else My Minolta DiMAGE X20 is doing the same thing and has...
thats called "vigneting" and is caused by misalignment of the lens.... has it been dropped or mishandled? if so, it needs re calibrating and setting up by a pro camera technician.
Mar 04, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Apple Powerbook G4 17in 1.33Ghz. Tiger OS. Airport problem.
I had a similar problem with my 15" 1.33GHz powerbook G4.
My problem was I couldn't connect to a network right away or at all, or wouldn't properly reconize the card (didn't drop it).
I solved it by removing the airport card from my PowerBook and putting it back into my G4. it should be in the same location.
it's underneath the battery pack.
1. power off your G4
2. remove battery pack
3. there is a latch on the right side (if the charger port is facing down), open it
4. pull back plastic cover tab and gently remove the antenna plug from the airport.
5. pull the plastic tab, until the airport card is removed, keep out for 30+ seconds to ensure it erases any corrupt log file on card it's self.
6 place airport card into the slot again, fully inserting it, it should go 1/8" - 1/4" into your powerbook
7. plug in the antenna plug back into your G4's airport(it should click 2x(very lightly)), flip plastic tab back over top the antenna cord, close you latch.
8. place battery back into your G4
9. plug computer in, turn on and it should work
if not then there is something wrong with the airport card reader, which i don't think it's the case here..
Jan 12, 2008 | Computers & Internet
Overheating PowerBook G4 17" 1.67Ghz
If you have AppleCare and your PB is less than 3 yrs old, take it in- that seems abnormal. It's really strange that your PB was heating up while it was shut down. THat indicated that there is s/thing wrong with the shutdown mechanism. Make sure the machine is hsut down before closing the lid. Let it rest a minute.
Jun 11, 2007 | Apple PowerBook G4 Mac Notebook
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
99 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
