Question about OKI Pacemark 3410 Matrix Printer
Printer Alarm Light
The Oki Pacemark 3410's alarm light comes on and stays on until I turn the printer on and off while holding the select button. I also get the message on the PC that says there is trouble printing to LPT1. All cable connections are good and I reinstalled the printer driver. Could the print head need replacing or is there some other issue?
  • 2 more comments
  • Anonymous Nov 28, 2007
    My printer will go on and after a few invoices it starts moving like something is holding it down or the ribbon is getting tight until it stops and the alarm light on. Then I turn it off and hold the select button down and turn it on again. It will work find until a few more pages.
  • pcsdrp Feb 26, 2008
    Each time I start my oki pacemark 3410 the alarm light comes on and stays on. I do not know how to reset it or clear the alarm. All of the buttoms appear to work.
  • stephiew Feb 26, 2008
    The alarm light on my OKI is solid read. I've turned it on/off, unplugged it from the print server and blown out all bits of paper that may be stuck. If I turn it back on, the paper goes up and down, but the cartridge doesn't move and the light stays red.
  • Anonymous Mar 21, 2009
    THE PRINTER ALARM LIGHT STAYS ON. I UNPLUGGED IT, TURNED IT OFF & ON, & STILL STAYS ON & WON'T PRINT
    Habit-Forming:
  • 40 Answers
Your carriage motor could be the problem.
Dezzi
Posted on Jan 04, 2008
2 Suggested Answers
SOURCE: OKI Pacemark 3410 Matrix Printer Error Writing to LPT1
A blinking alarm usually means an hardware error of some type, such as an obstruction on the printhead, or a bad motor or such.
When you have a blinking alarm light the other lights that are on will give you an error code that will tell you what the alarm means. You will need to look it up at Okidata.
Posted on Dec 10, 2007
Power light is on but no other buttons work.
I too have this problem. Any answers would be greatly appreciated.
Dec 01, 2010 | OKI Pacemark 3410 Matrix Printer
Is there a way to reset the printer if you want to stop a job midway when i print a report? OKI Pacemark 3410 Matrix
yes, clear all print jobs in the print queue on the PC.
The press "Stop" on the printer.
2. Turn the printer off for 1 minute the restart
3. Shut the PC down and restart.
This will clear the memory for both devices.
Apr 16, 2010 | OKI Pacemark 3410 Matrix Printer
Pacemark 3410 - printer shuts off after 30 seconds
Good chance the power supply is burned out. Located in the rear bottom of unit. You must remove the whole machine from case to get to it. Costs about $200.00 at any shop.
Aug 04, 2009 | OKI Pacemark 3410 Matrix Printer
Printer is offline
Press the most left button at the printer front panel.
May 06, 2009 | OKI Pacemark 3410 Matrix Printer
I have an Okidata Pacemark 3410 and the alarm light is blinking and will not print. i turn on and off and the alarm light just comes back on.
Normal 0 This doesn’t help fix all printers because each situation is different and in most cases we don’t have enough information to determine the fix. So hope this will provide some help.
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 29, 2008 | OKI Pacemark 3410 Matrix Printer
Theres power but no lights coming on
I think your power supply fan is faulty ?
Hope this helps.
Dezzi
May 27, 2008 | OKI Pacemark 3410 Matrix Printer
OkiData Pacemark 3410
Resolution:
Using HP JetAdmin.
Select Device then Modify
Next until arriving at the Options screen.
Here is where we make the necessary changes to the parallel mode and handshaking
Click on the pull down arrow and change the parallel mode to Centronics and make sure handshaking is set to nACK and Busy then click Finish. Reboot the JetDirect box and cycle the power on the printer.
Feb 11, 2008 | OKI Pacemark 3410 Matrix Printer
3410 Oki printer
If your print fades in then out every 5-6 lines, your platen probably has flat spots on it. This can be caused when someone forget to perform an alignment on a PH.
To run a test page you can power off the printer. Hold down the LF key and power on at the same time, this will print a self test.
Feb 04, 2008 | OKI Pacemark 3410 Matrix Printer
Oki pacemark 3410
Is the operating system Unix?
Oct 31, 2007 | OKI Pacemark 3410 Matrix Printer
OKI Pacemark 3410 Matrix Printer Logo
1,290 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
