Question about Ruud UBHC Air Conditioner
4 ton HVAC Unit for 2000 SQ FT Residential Bldg (Single Story)
Hello, my existing system for the existing 1500 sq ft residential bldg is not giving me enough heat or cold. I am thinking to replace this. With new 500 sq ft addition, Will a 4 ton system work for my home? How much would it cost. I want to install a higher tonnage for the existing 1500 sq ft, so that it also will work for the proposed 2000 sq ft with new add.
  • 38 Answers
Cost could count on the company that is going to install the system 4ton no ductwork can be around 7000 to 11000 dollars also depends on the type
Posted on Nov 26, 2014
  • 3,361 Answers
One ton of cooling per 500 square feet of space assuming you have good insulation. Yes, 4 tons for 2000 feet would be accurate.
Posted on Jul 21, 2009
How do i convert 60 tons of ashpalt to square yards
AC is approx. 145 lbs per cubic ft.
there are 27 cubic ft in 1 cubic yard
60 tons x 2000 = 120000 divided by 145 = 827.58 cubic ft divided by 27 = 30.65 cubic yards
square yards would depend on thickness of AC.
you can take thickness x sq ft to get cubic ft
in concrete 1 cubic yard =
4 inch thickness = 81 sq ft or 9 sq yrds
6 inch thickness = 54 sq ft or 6 sq yards
Feb 16, 2015 | Heating & Cooling
How many tons needed for 20,000 sq. ft.
There are so many variables that you should seek professional advice. The number of windows, insulation value and a number of other variables will all play into what size of cooler you are going to need.
Jan 26, 2015 | Carrier Heating & Cooling
How many tons do I need to cool a bldg 20,000 sq. ft.
Determining the total tonnage to cool any building depends on the heat loss calculations. Points to include is the R rating of the insulation, the square footage of the windows and doors, How hot does it get in the summer? Also the materials the building is made of. ie. Steel. concrete, wood exterior walls.
Jan 26, 2015 | Heating & Cooling
How to measure air conditioning tonnage to square feet of hom
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
May 28, 2014 | Computers & Internet
How do you calculate cfm for a room when sizing a hvac system fr a residential
their is a chart that homedepot use to give in a/c dept may still be their but a 6" run is about 100 cfm this will cover 10x10 1 sq inch is 1 cfm 1 ton is 400 cfm a gas system is 400 per ton and a heat pump is more like 425 but is best to figure the 400 cfm for both say you got 12x10 room that is 120 sq ft so you need around 120 cfm and if the 6" duct is 100% hard pipe with no flex you can get that if you balance your air if more help is needed email pendletonheatandair@hotmail.com please give me a vote and rating
Sep 22, 2010 | Cfm Heating & Cooling
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
Manual J Calculations for Residential house 1018 sq. ft. American Standard unit
without actually doing a load calc it would just be an educated guess.Good choice in equipment though.
Aug 06, 2008 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
712 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
