Caller ID (caller identification, CID), also called calling line identification (CLID) or calling number identification (CNID), is a telephone service, available in analog and digital phone systems and most Voice over Internet Protocol (VoIP) applications, that transmits a caller's number to the called party's telephone equipment during the ringing signal, or when the call is being set up but before the call is answered. Where available, caller ID can also provide a name associated with the calling telephone number. The information made available to the called party may be displayed on a telephone's display or on a separately attached device.
Step by step information at the link below. Brother Fax T96 The F/T
Mode is used to allow the fax machine and the telephones to share the
same telephone line. When a call comes in, the fax machine and all
extension telephones on that line will ring according to the number of
rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call
and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the
telephone line. If someone is sending a fax automatically , the sending
fax machine will transmit a fax tone (a series of beeps every 3
seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a
telephone (voice) call and will begin ringing the F/T ring tones (double
ring) for the length of time you selected for the F/T Ring Time. These
tones will only ring on the fax machine's handset (extension or external
phones will not ring). At the end of the F/T ring time the fax machine
will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
If you answer the call before the fax machine(during the ring delay
period) and determine it is a fax, you can transfer the fax to the fax
machine for receiving.
If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91
for New Zealand (remote activation code) on the telephone keypad, wait
to hear the fax machine turn on (chirping sounds) and then hang up.
If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the FaxStart or Start/Copy key on the control panel of the fax machine and then hang up the handset.
If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
The Blue and Blue/white represent the first pair in a multi pair telephone cable. The second pair is orange the third is green and so forth. If this line is active, you will get a dial tone when you place a telephone instrument on this pair (or any subsequent live pair). Notice. If you are hanging on to the pair when the telephone rings - you will experience a 60 volt DC shock. It will not kill you but you may find it unpleasant.
On your Western Electric '500' telephone set, you should have three wires coming out of the original cable, a red, a green and a yellow. Normally, the red and the green will operate your phone on a 'private line' (only one customer on a private line). Try various combinations until you get a dial tone. You no doubt have a private line as there are very few party lines around these days if you are in the USA (and please do not say). Once up on a time, there were "party lines" where neighbors shared a line and they knew the call was for them based on the number of rings. The first customer got one ring, the second customer got two rings and so forth up th as many as 4 rings. When the telephone rang, you listened for the number of rings and answered only if it was your number. Picking up a call that was not your ring was frowned upon though it was not unknown for neighbors to listen in to other neighbors calls. It was like a reality show!
If your 500 has been upgraded with a RJ-11 wire, plug the wire in just as you would any modern telephone. If yours doesn't ring, remove the cover and study the interface. You will find several terminals marked L1, L2 etc. Move the wire you find on a "L" terminal to the various otgher L terminals until it rings when called. You may also have to adjust the spring on the ringer to get it to operate properly.
I hope this information helps you get your 1960 telephone to work.
Thank you for your interest in FixYa.com and enjoy your old telephone.
Solution: Contact local phone company to check the telephone wall jack for low ring voltage.
Ring-in Voltage
Facsimile equipment?(fax machines), like other telephone anwering devices, require ring voltage at a telephone jack to answer automatically.? The ring voltage is one of the services provided by the local phone company.
Low ring-in voltage can cause short bursts of ring tones at the phone jack.
Callers may hear one or two ring back tones and then ringing will stop and nothing else will be heard.
Inside the home, the called party will hear a brief ring and then nothing else will be heard. If the telephone handset is lifted, the caller may be on the other end.
To check if the fax will not answer due to low ring-in voltage, do the following:
Disconnect the fax at the telephone wall jack.
If an answering machine is available, connect it directly to the telephone jack. If an answering machine is not available, connect a telephone to the telephone jack.
Dial the fax line and see if the answering machine answers the call, listen for uncommon ring tones inside the home or check for similar symptoms as described above. If any of the above symptoms occur, please contact your local telephone company.
