Question about Cell Phones
I have a just wireless bt-37k. Doesnt want to go in pair mode
I have a just wireless bt-37k. Doesnt have a light indicator to let me know when its in pairing mode so i dont know when to search or what button to hold. there is a + button on top a - button on bottom and a talk button in middle like any normal bluetooth just no light.
In the OFF mode, press and hold large button for 9 seconds until LED alternatly flash blue, red. After that you need to enter passkey 0000.
Posted on Dec 26, 2009
I don't have a fix. I just bought one myself and can't get it to sync. But once you have it powered on, there is a blue light just above the talk button in the top middle portion of the device. I just can't get the thing to pair with my phone.
Posted on Aug 31, 2009
How do i pair my jabra head to my phome
Hold the power button down until it either beeps or the indicator light stays lighted (this usually indicates pairing mode, might want to check manual to verify). Once headset is in pairing mode, go to phone's blue tooth settings and choose "pair" or "search for devices". This is pretty much the standard method for pairing devices using BT technology.
Jul 18, 2014 | Jabra Radio Communications
How do I set pairing mode
You will need to be sure that your device has BLUETOOTH. If it has bluetooth please turn on the bluetooth settings on your android device. You will now want to turn on the speaker.
Using the android device you will search for available bluetooth devices. Once you see BT-100 you will select that to PAIR. Some devices will automatically CONNECT after the devices have been paired. If not, please press BT-100 again to CONNECT. The BT-100 speaker should BEEP indicating that they have connected and the speaker is now ready to use.
If you continue to have trouble feel free to contact the manufacturer at support1@digixmedia.com or going to http://www.contelusa.net
Feb 04, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Not able to pair my bt-03a with my android device
Have you already tried to put your headset in pairing (discoverable) mode first? Anyway, in order to do it, starting with it turned off, press and hold the 'Play' button for some 7 seconds, until the indicator light is alternately lit in blue and red. It is in pairing mode now. Then, withing a couple of minutes, on your phone, go to 'Menu > Settings > Wireless & network > Bluetooth'. If the bluetooth radio is not turned on, turn it on. Then, tap 'Scan for devices'. After a little while, your headset should appear on the phone' screen. Tap over it to make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is succesful, your headset should enter the stand-by mode. An indication that a heaset is connected should appear on your phone too. If your phone indicates that only phone calls are available, tap and hold over it, until a context menu comes up, and select 'media', in order to make streamed music ffrom your phone sound on the headset.
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
Jan 20, 2012 | Genius BT-03A Bluetooth Headset
Pair to a sony ericsson w760a to a just wireless bt-35k2 bluetooth wireless head set
Put your device in search mode.
Put the bt-35k2 headset in pairing mode.
(Press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode.)
Once device detects headset, you'll be prompted for passkey; enter 0000. Pairing will complete once authenticated.
Dec 26, 2009 | Just Wireless Bluetooth Headset Wireless...
I can't operate the mouse. its not working.
Install fresh batteries, turn it on and make sure your bluetooth dongle is installed and active. If you have never paired this mouse with it's receiver, then you will have to put them both into pairing mode, and once paired you should have no problems.
Sep 16, 2009 | Micro Innovations Wireless Optical Travel...
Problems pairing my Just Wireless Blue BT-35K2
If you can get the headset into pairing mode, and your phone into detection mode and it's still not pairing, try removing the battery while powered on. Replace the battery and retry, and it should work.
Jun 26, 2009 | Cell Phones
Motorola H700 not connecting to nokia 6300
The factory code is 0000
Is there an error?
Enasure you are doing the pairing correctly
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator ight becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the headset boom, repeat steps 1 through 3
Jul 03, 2008 | Motorola Mobility H700 Wireless Headset
TRYING TO PAIR THE H700 TO MY TMOBILE WING
Just have to re-pair it.With the H700 BT headsets the pairing mode is different from other BT headsets. to put it in pairing mode you first hold the talk button on the headset until the purple light comes on.Right after the purple light comes on you have to flip open the headset for it to stay in pairing mode. From there you continue through the phone. It will ask for a password; that will be "0000". then connect.
Jan 28, 2008 | Motorola Mobility H700 Wireless Headset
How to synchronize to my phone
With the H700 BT headsets the pairing mode is different from other BT headsets. to put it in pairing mode you first hold the talk button on the headset until the purple light comes on.Right after the purple light comes on you have to flip open the headset for it to stay in pairing mode. From there you continue through the phone. It will ask for a password; that will be "0000". then connect. This headset can sync with laptop.
Nov 24, 2007 | Motorola Mobility H700 Wireless Headset
Cell Phones Logo
505 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
