I have a mita dc1460 WHEN I TURN IT ON IT SAYS REPLACE UNIT
IT WONT WORK AFTER THAT IT MAKES LOT OF NOISE BUT NOTHING ELSE HAPPENS
    President:
  • 3,085 Answers
You probably have a broken FUSER GEAR
Posted on Jul 22, 2009
Was fishing in heavy weeds with Minn Kota endura 50. I smelled faint electric burning and the wire & plug were hot. The unit stopped working. It this repairable at low cost or do I need a...
I have the same motor.That happened to me also luckily I only had a tangle of line I picked up in the weeds.Start by pulling off your prop and checking for something tangled around the shaft.If that is not the case,pull the front case off by removing the two bolts[they should be 10mm] and make shure nothing made its way into the lower unit.If all looks well reassemble and see if you can turn the prop shaft by hand if it turns freely with no noise try to run it.If it doesnt turn or makes a lot of noise chanses arethe electrodes that make the prop turn are out of place.If that is the case get back to me and I can take you step by step in resetting the electrodes.Good Luck.
Jul 17, 2011 | Sport & Outdoor - Others
I have a 2005 neon and my turn signals wont work. the flasher was making noise and only working on ocassion. so i replaced that and they worked once and now they wont work at all. so i replaced the turn...
There are two fuses that feed the turn signal switch one is located in fuse one of the fuse block the other is fuse fifteen in the power distribution center.
Apr 13, 2011 | Dodge Neon Cars & Trucks
Ariston AWD 121 wont work
make sure the water supply is turned on , a small red and blue tap usually under the sink
Nov 11, 2009 | Ariston Technologies AWD 121
Washing machine makes noise but wont spin or
THERES A THREE PIECE COLLECTOR BETWEEN THE MOTOR & THE TRANSMISSION EASY TO GET TO EASY TO CHANGE
Sep 21, 2009 | Washing Machines
Require a part number
call a copier company specializing in keyoceria they took over mita
Apr 23, 2009 | Kyocera Mita Office Equipment & Supplies
The screen says AP -what does that mean
AP means that the copier is going thru a major toner cycle.
Sometimes when you drag a lot of toner out for dark copies, the normal toner cycle is not enough.
The spring that takes the toner from the cartridge to the dev unit mat also be faulty or broken.
Sometimes the AP message will go away but make sure you have plenty of toner.
Feb 09, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
90 series dryer wont start
first check and see did any clohes fall down in the blower wheel,,from fillter no...check the belt that its not jammed,,check your idler wheel ...always unp[lug unit first.....now we will check motor ,turn unit on if you get a humming for about 10 to 15 seconds than a click,,replace motor
Dec 25, 2008 | Kenmore 63942 Dryer
82 people viewed this question
jasbo
jasbo
