Question about Philips 60PP9363 60" Rear Projection HDTV-Ready Television
Changed convergence ic's and now no picture oh phillips 60pw9363
I changed out the ic's and in the midst of everything pulled out one of the 3 big wires that go into a black device that looked like they were spark plug wire looking... i put it right back in. when i finished everything the power light comes on but there is no picture at all. need help. did i damage the black thing by removing the wire?
  • Philips Master
  • 3,459 Answers
No - but make sure the wires are seated. The most likely cause for no video is you did a poor job on soldering. Goto www.TvRepairKits.c com and look under their tip section. They have a free guide on how to solder.
Posted on Jul 22, 2009
Changed ICs Chips but still got bad convergence
After the IC replacement, convergence adjustments should be done. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Details of this adjustments are given.
May 01, 2017 | Philips 60PP9202 60" Rear Projection...
Picture gone screwy
The two lines, do they appear like a picture in 3-D? If that is the case, the convergence amp IC's probably were weak already, and took a dive when you were adjusting the set. As when the picture changes, so do the voltages on the power supply shift a little. I think you may have a power supply problem as well. Probably a capacitor in the main supply that gives you the plus and the negative voltages for the convergence. If you have the knowledge of soldering and working on printed circuit boards, you can change the two convergence IC's first. After that measure the + and the - voltages on the IC's and see if they are low or vary any significant amount. If you cannot solder, maybe a relative, friend, or maybe a neighbor can assist you, as changing the convergence IC's is not really difficult. A repair person will charge you anywhere from 300 to 400 bucks for a job like this. The IC's only cost about 15 bucks or so each. Good Luck, and let me know if you can handle this repair and if you need any more information's regarding this repair. Oh, one more thing, it is always a good ideal to get the service manual for this set, so you will know what and where everything is and can make any adjustments after the repair. The manual is available Here; http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=61HX70
Aug 04, 2007 | Toshiba 61HX70 61" Rear Projection...
Philips 60pw9363 convergence issue
there is a convergence repair kit for ypour model which has both convergence ICs and all 12 Feed resistors at the following link. They also include step by step instructions with pictures of how to do the repair. Heres the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Feb 03, 2009 | Philips 60PW9363 60" Rear Projection...
Red sideways hourglass
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jul 20, 2008 | Philips 60PW9363 60" Rear Projection...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version.
Good Luck, Big Irish.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
Phillips 60pw9363 Which IC is red and which is blue
Thats the DPTV 335 series chassis when the IC blows it will usually take out 1 or 2 6.8 ohm resistors along with it. Look at the resistors right next to the ICs you will notice 1 or 2 with a little discoloration in the middle replace those and your set should be back to working just fine. Let me know if you need more help. These resistors are easy to spoy they all look alike and shouldnt have any bands on them they will be stamped 6R8 ohm 1W J
Apr 12, 2008 | Televison & Video
PHILLIPS BIG SCREEN TV IS BUTTERFLIED
Are the colors out of alignment and unable to converge back? If so its the convergence ICs need replacing. If the convergence isnt out of alignment you have whats called a pincushion problem. If you would like a link to where you can obtain the service manual for this model let me know.
Mar 17, 2008 | Televison & Video
Convergance adjustment
convergance amp ic bad
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
PT-47WX53 blue convergence
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Philips 60PP9363 60" Rear Projection HDTV-Ready Television Logo
153 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
