Sewing Machines Logo
Ellen Hopkins Posted on Jan 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get the bobbin case out of a Viking 500 in order to clean thanks
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
  • Posted on Jan 16, 2017
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2613603
Points
59176
Page 51 of the manual download here (HClass 500E):
http://manuals.husqvarnaviking.com/
I need bobbins for my viking 500 computer machine. the green do not fit my machine. I need the clear bobbins. Where do I puchase these?
I found the answer for your bobbins when searching online for Viking 500 the below website where you can order parts. It aslo has a 10% off coupon for your first online order: https://www.sewingpartsonline.com/viking-500-sewing-machine-parts.aspx
How do I oil my viking sewing machine? I have barely used it in the 10 years I have owned it, so I don't want to pay for a full tune-up. I'm sure it's linty and gummy inside.
The Designer II should not be oiled by the user. As with most computerized sewing machines, it's got a sealed bearing system. You do need to clean the bobbin area and the space under the bobbin case. See page 65 of the user manual to open stitch plate to clean the bobbin area and feed dogs. Next remove bobbin case holder and bobbin case to clean under there. Sometimes the interdental brushes can get some of the lint that the sewing machine brush misses.
The manual for the Husqvarna Viking Designer II is available on the product page: http://www.husqvarnaviking.com/en-US/Machines/DESIGNER-II . The current link to the manual is http://www.husqvarnaviking.com/getattachment/Machines/DESIGNER-II/Designer-II.pdf.aspx .
I hope this helps.
Reinsert the bobbin case in Viking 500
after removing the needleplate and gray bobbincase retainer, manually rotate the handlwheel so that the tip of the hook is between 11oclock and 10oclock. carefully insert the bobbincase into the hook assembly so that the gap in the bobbincase is centered below the feeddogs. manually rotate the handwheel slowly to confirm that the bobbincase is fully seated into the hook assembly. reinstall the gray retainer and then the needleplate. again manually rotate the handwheel to confirm that everything is seated correctly.
Price removed casing round bobbin and inner case to clean fluff , now I carnt seem to line up properly although all slots back the needle won't go down properly .....husqvarna Viking E10 ..man
Remove bobbin case completely and check that the needle will go down properly. If so, put the bobbin case back in lining up the black arrow on the bobbin case (on left hand side) with the metal arm that comes out slightly on the left side. Sometimes, it is tight getting the case back in place properly. Once in place, check that the case will rock back and forth slightly.
Hope this helps.
If you are still having trouble, most Viking dealers will be glad to assist you in the store. You can find the Viking dealer nearest you using Locate a Dealer at the Husqvarna Viking website -
http://www.husqvarnaviking.com/us
Trying to clean under the bobbin case on Viking Emerald 183 and I can't get it out.
When looking at your bobbin case from the top you will notice the hook. Think of the tip of the hook as a clock dial. At 12:00 the hook would be behind the needle. Turn the hand-wheel is at 10:00 this will allow more clearance when removing the bobbin case/basket.
I HAVE A HUSQVARNA 415 SEWING MACHINE. I AM LOOKING FOR THE NAME OF THE PART THAT YOU PUT THE BOBBIN INTO. I ORDERED A BOBBIN HOLDER, BUT THAT IS NOT IT.
The bobbin fits into a bobbin case (holder), the bobbin case is what you take out to put a new bobbin in. The bobbin case fits into the hook (it has a spindle in the center) which you do not take out of the machine unless you are doing maintenance. If you just ordered a bobbin holder, it could be for another machine. you must get a case made for the machine, a generic one will not work.
Husqvarna viking Platinum 775 fabric won't advance
Most of the time the bobbin case gets hung under the feed dogs, take your needle plate off and the bobbin cover there is a gray colored finger with a number 10 torx screw holding it in you can also try a small flat head screw driver, remove that finger and then remove your bobbin clean the hook out and replace the bobbin making sure it seats itself on the hook with the small notch on the bobbin case lining up with a small metall spring on the back right side of the hook area.
4answers
Missing bobbin case and bobbins Husqvarna 4000-serie sewing machine
ask where Husquvana machines are sold. google dealers if you don't know.
Husqvarna Viking #1plus bobbin problem
Suggest that it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
