Question about Samsung HL-R5087W 50" HDTV-Ready Television
HDMI port on xbox 360 has bent pins
The pins bent some how, it doesn't appear that they'll be fixable with a knife.
    Scholar:
  • 122 Answers
Bent pins are a tough problem. In a lot of cases when you try to straighten them they break off. The best system to try is with very small needle nose pliers. Gently grasp each bent pin and bend. They don’t have to be perfect but close. Work on one at a time and work slowly. Still it is just a chance it will not break. Good Luck.
Posted on Jul 22, 2009
Hook up xbox 360 tv
What kind of receiver? Do you have anything else like DVD player going thru receiver? My receiver has 3 hdmi in and 1 out (to tv) so all those equipment would just go to "hdmi" on tv.
Another way to do it is put your tv on exterior audio... for all sound to go thru your receiver.
Jan 05, 2014 | Televison & Video
XBOX had no power, so I found and repaired bent USB port pins, then the XBOX came on with three red lights. Any DIY repair possible?
Thanks for your question. To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in to microsoft.
Jan 09, 2013 | Microsoft Xbox 360 Console
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
I HAVE 4 RED RING WHEN I TURN ON MY XBOX
Solution
Mar 23, 2010 | Microsoft Xbox 360 Console
Can i get me xbox 360 upgrated to an xbox 360 eleat
Xbox 360 Elite has a bigger hard drive and a HDMI port. [Some non-Elites already have a HDMI port]<-- if you dont.. you CANT add a HDMI port..
geting a 120GB .hard drive will be the only upgrade that can be done
Nov 24, 2009 | Microsoft Xbox 360 Console
Xbox 360
Hi pcon21,
I suggest keeping the new Xbox 360 because the new one should have the HDMI port and the older Xbox 360 does not come with the HDMI port.
Sincerely,
Agent Xiong
May 14, 2008 | Microsoft Xbox 360 Console
Xbox 360 HDMI Audio Analog
http://forums.xbox-scene.com/index.php?showtopic=415408
Jan 07, 2008 | Microsoft Xbox 360 Console
Controller port usb pins are bent
is it in the warrinty / do they cover it
Oct 20, 2007 | Microsoft Xbox 360 Console
Open Questions:
Samsung HL-R5087W 50" HDTV-Ready Television Logo
673 people viewed this question
Henry  Thomas
Henry Thomas
