Question about Kitchen Ranges
I have an Amana ACS3350AB gas slide in range. Recently the electronic control panel began shutting off while I am baking. The oven goes off, the clock, etc. The front panel gets very hot to the touch on the outside of the stove. Repair people have been here twice and appear to be guessing about the cause. Any ideas?
    Novelist:
  • 108 Answers
Does the door seem to be closing all the way? I'm thinking that there is a heat sensor that is turning off the oven so that you don't melt the computer board... but that's just a guess
Posted on Jul 22, 2009
The heating element goes on but the oven does not heat up. A few months ago noticed that it began to heat up very slowly. Now does not heat up.
Hello, dinophyl (early Jurassic protozoa, hey) Do you have a Gas or Electric kitchen range? Very good possibly that the thermostat control in the oven is bad. That little brass bulb in the oven. This controls the internal temperature of the oven. If it an electric range then the the electrical thermostat on the oven knob could also be the culprit also. GB..stewbison
Sep 24, 2011 | Amana ACS3350AS Gas Kitchen Range
1.Our gaz range (with electronic range control) Amana ACS3350AS oven bake works normally at 350 F for 40 minutes, then stops. While the broil can still work at this point, it's likely the Oven - High...
Works normally for 40 minutes? Then after she cool down will work again? Let me look un momento mon ami. Aha Your temp sensor might be faulty,
Another thang it could be is a weak ignitor,
An oven limit would shut down and NEVER come back to life. It ain't gonna be no limit er fuse.
Basic American oven fault codes and more HERE
Feb 11, 2011 | Amana ACS3350 Gas Kitchen Range
Ovens temps are generally controlled by a probe with two wires called the oven probe(1100 ohms at room temperature for a good one) This probe connects to the main erc control board, which as temperature rises, it changes resistance reading, which is read by the board.......These usually show a fault code on the display when one fails........
The oven ignitor is glowing which ignites the flame. Usually this has to read between 3 to 3.5 amps to be good. (can be 2 or 2.5 and glow and the gas valve will not open) If the ignitor is glowing after 40 minutes, it is most likely the ignitor is bad. (the broil has a separate one, the bake has a separate one) If you do not have a amp clamp to test, you will need to replace part and see what happens, if it fixes problem.......good luck (it could be a sticking gas valve or relay but the ignitor is the most common failure, fragile part also, do not drop it)
Amana ARGS7650SS Gas oven takes a long time to heat up, and then, in the middle of baking, the digital control panel goes blank and the oven goes off. Eventually, the panel will begin flashing and, with...
This is Amana's fault and is common on several oven models and types.
Your timer and clock control board has some loose solder joints and they can be re-attached by any competent electrical repair shop with soldering skills. TV shops can often be convinced to do this for you for a nominal fee.
Nov 07, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana, ACS3350, gas slid - in range, the oven will not turn
I just had the same problem. I had it repaired and it was the oven ignitor. Labor and Parts $185. I now have an additional problem and I have to call the repair person back. The oven starts up and preheats to temp I set of 350 degrees. Then after awhile it will shut off and after another few minutes the clock will come back on and blink. I will repress oven bake and it will go for a short time and then shut off. I don't know what the problem is yet. I am totaly dis gusted with this stove. The stove is only 8 years old!
Jun 08, 2010 | Amana ACS3350 Gas Kitchen Range
The Bake ignitor in our Amana Gas Range (model #ACF3375AW) recently began to only work intermittently. Now it doesn't work at all. The Broil ignitor works fine. Any ideas? Thanks! Dana - Minneapolis
Hi Dana from Minneapolis...you need a new Bake ignitor, which is also called a glow coil. When it's working properly it glows a white hot colour and as it wears out it will glow an orange colour and needs to be replaced, this is why it began failing and then quit altogether. This is a part that requires an authorized gas technician to install for you. Good Luck.
Jan 26, 2010 | Amana Kitchen Ranges
Amana gas range
the only f5 code listed for the amana range states faulty erc(electronic range control) solution replace control
Feb 19, 2008 | Amana ARGS7650SS Gas Kitchen Range
Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Amana ARGS7650SS problem
try this site - repairclinic dot com. there are some helps about where the screws are to remove the control panel.
Aug 21, 2007 | Amana ARGS7650SS Gas Kitchen Range
Kitchen Ranges Logo
227 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
