Question about Kenmore 44072 Front Load Washer
Washer fills up then nothing else happens will not wash or spin it will fill and empty
Washer fills up, but the drum will not turn to wash or even spin.
Posted on Aug 02, 2009
  • 90 Answers
If u hear the motor running after it fills then u need a motor coupling
Posted on Jul 22, 2009
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
The washer will not agitate or spin out. the washer will fill and empty the water.
The most likely cause is the motor coupling, one on the motor and one on the transmission. UNPLUG POWER FROM WASHER. If it is broken your washer will fill and you will hear the motor running but nothing will happen, no agitation or spin. You will need to loosen the console, remove the cabinet drain pump and motor, then the motor coupling can be replaced on the motor and transmission. Part comes as a kit. Part number 285753a. Please rate this post.
Dec 14, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Washer filled with water and then does nothing but make a clicking noise
If it's not spinning, the transmission is bad. If it's just not emptying the water, the pump is clogged or bad.
Unless you can replace the transmission yourself, it would be a better bargain to buy a new washer.
May 03, 2009 | Washing Machines
Top loaing washer fills then mostly empties repeatedly
Check you drain line. It may be too low or the air gap is blocked at the drain pipe.
A test is remove the drain pipe from the wall drain. Hold it up high and turn the washer on to fill.
If it fills and stops, then starts agitation. Repair the drain hose.
Mar 23, 2009 | Kenmore Washing Machines
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Frigidaire Washer/dryer combo
Dtronics,
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
handiman518
Nov 13, 2007 | Frigidaire FEX831CS Top Load Stacked...
Washer will not spin
normally i would suggest changing motor carbons for hotpoint washers, but my experience is that the WMA motor armature is weaker than the carbons, normally if there is no connection fault a replacement motor is the answer 9 times out of 10, not a job for the amature
Aug 28, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore 44072 Front Load Washer Logo
400 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
