Question about Whirlpool Calypso GVW9959K Top Load Washer
Can hear the motor running on spin cycle but tub is not moving
  • 32 Answers
Robrox44,
Sounds like the drive belt on the moter is broken. click here to see where it is. It shows in the picture at the bottom.
-Hope this helps, samson39
Posted on Jul 24, 2009
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
The tub will not spin in the rinse cycle
This sounds like a timer problem if it will spin in other cycles. If you hear a motor running but no spin it is the motor couple.
Mar 12, 2009 | Whirlpool Washing Machines
Washer motor spins but the TUB does not (intermittent)
If the motor is running and the tub is not spinning you must remove the motor and inspect the drive coupling.
One of the 2 plastic pieces could be stripped or cracked.
If the drive coupling is intact, proceed to the clutch on top of the transmission.
Replace the clutch linings.
Mar 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer tub will not move on any setting
SOUNDS LIKE A BROKEN COUPLER, YOU WILL FIND THIS BETWEEN MOTOR & TRANSMISSION.
Jan 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag A482 top load washer
The timer is faulty and needs replaced.
NOTE:
There is a possibility that only the timer "motor" is bad. This motor can be replaced. Listen at the timer knob. If the motor is running you can generally hear it this way.
Because of the age of this machine it is best to replace the timer
Jan 09, 2008 | Washing Machines
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Where is the agitator in a Indesit WG1385
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Jun 07, 2006 | Indesit W 123 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
