SOURCE: Norelco Electric Razor problem: Jet Clean System won't work
You need to fill the based to the max solution line. There is not enough solution in the container.
SOURCE: how i clean my razor
I have this razor as well. Just flip the heads open, dump the hairs in the garbage and rinse the heads (while open) under hot water. Keep the heads open until dry and close on up.
SOURCE: How long should heads last on Norelco Arcitec
Norelco suggests changing the shaver heads every 12 months for best performance. If you need to buy some, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
SOURCE: Arcitec razor 1050X will not cut whiskers
You are certainly not th first person who hasn't been happy with the Arcitec model. If it never worked well for you from the beginning, there is nothing that will make it work now. It's a shame that you've waited past the 45 day return period.
Your old shaver, 6885XL, was a "Quadra" model. These were a popular model type that is now discontinued. If you still have it, it may be able to be repaired. If you would like to replace it with another Quadr model, you will find one at shaveroutlet.com. See link below
http://shaveroutlet.com/shavers/norelco-7886xl-quadra-action-shaver-factory-refurbished-p-534.html
This model is virtually identical to your 6885XL except that it is a newer version
SOURCE: how to remove the blades
On Arcitec shavers, the blades can not be removed from the head assembly. This makes it difficult to thoroughly clean them and they must be replaced reqularly because of this.
If needed, you will find replacements at shaveroutlet.com.. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
