Question about Ventamatic Gable Mount Power Attic Ventilator Fan
I have 120v going to fan ,thermostat has been put on 80 degrees and it still won't work .Do the heat sensors go bad ?
    Genius:
  • 1,114 Answers
The heat sensor or thermal switch can go bad, so can the motor.
Try a few things;
shut off power going to fan. try cleaning out the thermostat housing using some compressed air on low pressure, or use a vacuum cleaner on blow, or a hair dryer on no heat. you can also spray the inside with contact/motor cleaner(home depot electric dept.) and then blow the thermostat out of any dust or particles that may have lodged inside.
To see if the thermostat works at all, turn power to fan on. Take a hair dryer on heat and place near thermostat - to see if fan comes on.
To rule out a bad motor, the thermostat can be bypassed by hooking up the feed wires to the fan itself, if you're handy with wiring.
Ventamatic web site does list replacement parts for fans... Good luck!
Posted on Jul 22, 2009
Water pressure good, thermostat calling for heat boiler ignites , heats to 80, turns off, drops to 40 reignites - keeps this cycle going. temp sensor? return sensor? any help appreciated
the thermostat has an upper and lower setting at which point to turn the unit off and back on
most have a 10 degree variation between off and on so that a steady temp is maintained
check to see if the lower setting can be raised closer to the 80 degrees
if not consider a new thermostat with closer settings
Feb 13, 2016 | Water Water Heaters
My Dometic digital thermostat wont go up past 32 degrees. What could be wrong?
indicates inside sensor defective or not communicating resulting in a/c being locked out.
Sep 16, 2014 | Dometic 3313192.000 White Single Zone LCD...
New oven won't heat
1.Check sensor connection. 2.Measure sensor resistance (1080 Ohms at 70 degrees F. Add 2 Ohms per degree F). 3.If resistance is not valid, replace sensor. 4.If sensor resistance and connections are good, then check for welded-closed relays on the control.
Here is the sensor to order if it is bad.
Nov 28, 2012 | Ovens
2002 chevy malibu heats up when running at low speeds
CHECK THE THERMOSTAT. THERMOSTAT IS THE ONE THAT SENSE THE ENGINE TEMPERATURE AND TURNS ON COOLING FAN WHEN THE ENGINE IS HOT.
Jan 19, 2012 | 2002 Chevrolet Malibu
2000 daewoo leganza is overheating, leaking anti freeze, and water. what is wrong?
sound like thermostat sticking close.replace thermostat and radiator pressure cap.if already done.you could have faulty water pump.if engine overheating at long slow traffic line or setting at a stand still.the engine cooling fans should be running, check and see if cooling fans running if not,check cooling fans fuses and relays.if all is good,hot wire make sure coolings fans okay.if all is good,code scan vechicle for faulty engine coolant temperature sensor and ecm problems.you need a code scanner where you can check live data check see if coolant temperature sensor reading correctly if engine coolant temperature is 190 degrees the coolant sensor. the scanner suppose to show 190 degrees in temperature if not it reads 80 or 90 degrees the engine coolant temperature sensor is faulty need replacing.if all is good check engine oil if look like milk shake blow head gasket will cause over heating.to be on the safe side i would replace thermostat and radiator pressure cap first.to make sure engine coolant circulating through radiator and engine block.
Nov 15, 2011 | 2000 Daewoo Leganza
I recent replaced the coolant temp sensor and themostat make by duralast.and the sensor was bad because it made my car overheat..it never kick on the high speed but it did kicked on the low speed fan at...
Looks like you need to replace your upper hose as it may be faulty, if you can easily pinch it together, then it's bad. also i would replace the radiator cap as well if it hasn't in a while. Has the water pump ever been replaced?
Jul 28, 2011 | 1998 Oldsmobile Intrigue
Cannot get cooling fans to turn on for radiator???
The cooling fans won't run until either the engine coolant temperature reaches about 218 degrees or the air conditioner/defroster are on. Once the engine reaches appx 218 degrees the fan will come on and run until the coolant temperature drops a few degrees and will then turn back off. If either the a/c or defrost are turned on then the cooling fan will begin to run to remove the heat from the a/c system and should stay on until either is turned off. If the engine is overheating in slow or stop and go traffic then the fan may not be working at all due to a bad fan motor or blown fuse.
Nov 12, 2010 | 1997 Chevrolet Lumina
94 cutlass supreme is overheating,all fluids are fine. I did have someone tell me i need 3 motor mounts replaced. could this be an issue of the car overheating?
Over heating can be caused by a faulty thermostat and or weak water pump and dirty radiator and old antifreeze or the radiator fan now working when at idle but should not over heat when driving. Service the cooling system if it has never been serviced before. Replace the thermostat, buy some radiator flush to clean out the radiator and heater core. Just follow the instruction and replace the antifreeze and make sure it's a 50/50 mix water/antifreeze. If you not sure how to mix it 50/50 you can buy them 50/50 premixed. Water boils at 100'C so you need antifreeze mixed with it but antifreeze does not have the same heat transfer as water so you cannot run 100% antifreeze cause it does not transfer heat fast enough and you over heat. Good luck and hope this helps. Keep me posted, Be glad to help, once you service the cooling system and your still over heating, then we look at the water pump.
Jun 16, 2009 | 1994 Oldsmobile Cutlass Supreme
Robertshaw 9600: Temperature rises too high, fan doesn't stop.
It sounds like the thermostat is wired improperly. One quick was to check is by finding breaker to unit and shutting off power. Go to thermostat and remove from wall take all wires off thermostat besides wire going to R(might be RcandRh) and C(which is common) Tape all bare wires removed with electrical tape. Now go back to the breaker and turn power back on. Nothing should be running at all. Take a voltage meter and measure the voltage from R to W(which is heating). If you read 24V then the thermostat is open and not calling for heat. Now turn the thermostat up so it is calling for heat. You should read 0V from R to W. If this checks out your thermostat is probally fine. You can check the fan the same way by going from R to G. In auto you shoul read 24V from R to G and in th on postion you will read 0V from R to G. If the thermostat checks out then the problem is probably at the furnace or rooftop. Either with the thermostat wiring or the main board acting up
Jan 19, 2009 | Heating & Cooling
Ventamatic Gable Mount Power Attic Ventilator Fan Logo
254 people viewed this question
Top Ventamatic Dryers Experts
Dan Webster
Dan Webster
Are you a Ventamatic Dryer Expert? Answer questions, earn points and help others
