Question about HP Pavilion dv9700t Notebook PC
Screen stays black
I have hp pavilion dv 9700 notebook pc, and the it wont come on, the screen stay's black? what can I do?
  • Anonymous May 11, 2010
    Does the power light stay on? Did you check to see if your battery pack is in tight and secure? Did you check your power cable connections at the notebook, at the power adapter and at the wall socket? Is the power light on the power adapter?
  • 33 Answers
There is few reason. Either your one of RAM is defective. Try both memory one by one. Even though if U don't see screen than its time to change motherboard.
Posted on Jul 22, 2009
Screen stays black when I turn it on
My point of view RAM section direct connect to display so first you check RAM.Then check processor Fan proper working or not. and finally power connection in screen.
Thanks..
May 08, 2013 | HP Pavilion ze4935wm PC Notebook
My HP Pavilion dv9000 Laptop powers up but screen stays black. Keyboard lights up and you can here the computer running.
Connect it to an external monitor to see if it shows video.If it does the display panel needs to be replaced.If it doesn't show video the video card is most likely malfunctioning.The HP dv series are bad about having video problems due to heat and depleted thermal grease.Hopefully it will show video on the external monitor.
Jan 26, 2011 | HP Pavilion dv9000z Notebook
My HP Pavilion dv2000 turns on, but screen is black
If the laptop appears to boot up but the LCD screen is black, then the problem is a back-light fault caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 14, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hey, i have hp pavalion DV 1000 with a 512 mb ram and XP operating system. my laptop was having heat-up problems thus trying to put a 1 gb ram in it . yesterday the display went black ,i actually just...
If the PC boots and the screen stays dim, you probably have a bad LCD inverter or backlight. The inverter is the easier fix of the two, the backlight usually requires some soldering. Unfortunately, it is generally the more complicated solution.
Oct 26, 2009 | HP Pavilion dv1000 Notebook
Black screen on my HP Pavilion DV2000 Laptop
for all dv i think it depends with the area u are staying coz from Africa here there is no warranty for any pavillion esp those dv 2000,6000 etc
bt wht u can do is to try to reset the system by removing the battry and power thn u press the power on batton 4 i min,thn put evrthin together
Aug 11, 2009 | HP Pavilion dv2000t Notebook
Hp dv6000 black screen problem
tipical hp problem, if no warranty buy a new laptop "not hp", its called "the good old fashion hp graphic chip burned"
Jul 02, 2009 | HP Pavilion dv6000z Notebook
WONT BOOT BLACK SCREEN
this is a easy one plug up your unit take out ur battery for 30 sec while holding do the power button hit the power button once again and it should come on and if it dont the great things is there a recall on those pc call hp they will send u a new pc free of charge
May 22, 2009 | HP Pavilion zd8000 Notebook
Can not see anything on the screen
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 28, 2009 | HP Pavilion dv9700t Notebook PC
Hp dv 2000 my screen stays black when switched on.
Check all you cables etc.. If this does not correct the problem it is most likely the video card integrated on the motherboard.
I had a dv1000 do the same thing. The bad news is the motherboard will have to be replaced.
Dec 11, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Open Questions:
HP Pavilion dv9700t Notebook PC Logo
500 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
