Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod ------------------------------------------------------------------------ Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. BE CAREFUL and do not delete files needed to operate your MP3 player.
Please rate me
I have a dffierent mp3 player Colby with a usb and I had the same problem. Try deleting the songs from the device itself. If you go into folder view if you havet hat option and choose the song it says to play or delet, at least that is what mine says. It may take awhile to do it one song at a time, but you should have the option of deleting the songs from the actual mp3 player.
I also had minenot show up, mine was do to deleting some of the software off of the player to make more room for songs. I never used podcasts and other files that came on it, so after I deleted them my songs stopped showing up. I just copy the songs to my mp3 player now, and delete them one by one. Hope this helps you.
I've worked mine out. When I put the songs on my MP3 I used Vista, I then changed to an XP install and this is when I couldn't see the songs on my MP3 player. When I went back to my Vista install I could see and edit the songs. Now I have cleaerd it I can go back to my XP install and use it as normal again. Basically you need to use the same version of windows you put the songs on with to edit them.
To delete songs from your device follow the steps below You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there. Either under sync panel in your windowsmedia player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete. To format it..on your device..go under..menu, setting and there should be a format option option there..let me know if that doenst work for you... Hope this helps
P.S.Please rate accordingly... Thank You Computerrep
sync mode in windows media player is used to add in music, to delete songs, on win media player 11 click on library and then on the left side of the player there should be a list, on the list should be "Sansa C240", click on that and then find the your music, right click and delete. Or you can always click on the arrow below "sync" and then go to format to delete all songs.
If you go under settings there is a reset there. You should also be able to access your songs from your PC when u plug in your USB & could delete songs there. Might also want to look into getting a micro SD if u don't already have one. Good luck!
