Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Sears electric oven
Broiler does not work.
Broiler fuse ok.
Element checks ok with an ohm meter.
Boiler relay clicks on when broiler function is enabled.
No error codes.
  • 35 Answers
Replace broil element
Posted on Dec 09, 2007
Turn my oven to preheat, broiler comes on and not the bottom element. Checked the ohms on element and it did move the meter.
Check the broiler element, and see if get the same reading.
Does the oven heat on normal "bake" settings? If so, the bottom element is fine, and it's the "brain" not telling the bake element to get hot.
Jun 08, 2015 | Ovens
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Feb 09, 2014 | Thermador SEC301 Electric Single Oven
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Thermador SEC301BB broiler doesn't work
the broil element
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
I have a G.E. self cleaning oven, the broiler works however the oven does not
if the unit is gas it may be the ignitor and if elect it may be the bake element . remove either and ck it with a ohm meter . . also ck the house fuse . making sure the power to oven is ok . if broil works power is probably ok ..
Aug 11, 2010 | Ovens
Hotpoint oven not heating up;broiler ok
the element is burned out, remove itand check it with a ohm meter. if it moves when you touch the leads to both sides its good if it don't its bad. ps i take them all the way out to check them. you must unplug the oven before repairs!
Jan 19, 2010 | Hotpoint SY36 Style Line Stainless Steel...
My oven has increased only 65 degrees in almost an hour....what does it mean when it heats up, but SLOWLEY??
The broiler element on the top of the oven comes on during the preheat cycle to speed things up and then only the lower element keeps the temperature steady. One of those elements is bad, probably the broiler. Try using the broiler and see if it works. If not, you need to disconnect the elements from the oven and check them with an ohm meter. If gthe elements check out ok, then it must be the temperature sensor/thermostat.
Jun 25, 2009 | Frigidaire FEB27S5A Electric Single Oven
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
Frigidaire Double oven PLEB30T8AC
The best way for you to check is to swap with other element since they use the same one. FRIST turn the breaker off! Then take out the 2 screws on the element. The wires unplug, make sure they don't go back in the holes or the oven may have to come out to find them. You can pull the element out and take it to a parts house to see if they can check it with a ohm meter for you if you don't want to pull both of them out.
Apr 15, 2008 | Frigidaire PLEB30T8A Electric Double Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
153 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
